Thread: tune question
Results 1 to 9 of 9
  1. #1 tune question
    NY
    Anyone ever ran across an issue with the ltft's going all over the place even after tuning the maf in close? I can hit the same cell and maf frequency numerous times and they never hit the same value each time. For example I'll hit the 5000 freq and one time it will be +7, next time it will be -6. And yes I have dialed in the maf tables close to 0
    This is making the final tuning a super big chore as it's never consistent.
    2001 Regal-GMPP handling, shift kit, tuned, ported Gen3, 3.6, N*, SLP dual catback, Aeroforce
    70 Monte Carlo 12.5@109 waiting on new setup
  2. #2 Re: tune question
    Feb 2009
    flintnasty MI
    I posted a significant amount of information in this thread.
    If you dont want to read it, the short story is, narrowbands are stupid, and you shouldnt ever tune a factory maf.
    http://www.grandprixforums.net/showthread.php?t=85110
  3. #3 Re: tune question
    Says he's got a N* in his sig, might be a cause there.
  4. #4 Re: tune question
    NY
    I have read that thread but I'm referring to my ltft's at non-boost levels. It's being a pain getting the trims to come in line to 0
  5. #5 Re: tune question
    NY
    Yes, I've got a N* and a different maf then anyone is probably running too.
  6. #6 Re: tune question
    Arizona
    First things first are you reseting yourtrims each time you make your changes? Are you multiplying percent half each time you make your changes?
  7. #7 Re: tune question
    NY
    Yes I'm resetting the trims each time and give it sufficient time to relearn. My changes are made though table modifier program used with DHP and some manual changes but small. The ltft's are just being difficult to keep in line and seem to be tqwice as bad when it's below 30*. I've noticed the past few days too that my O2 reading seem to be lazy, but not throwing a code
  8. #8 Re: tune question
    Arizona
    Can't help you with dhp sorry. However usually when 02's start oscillating really slow at any engine temp it indicates a dying sensor which I'll make tuning with trims a nightmere.
  9. #9 Re: tune question
    NY
    I did just replace the O2 with a new Delphi when I did the header install. I'm thinking I might be having a issue with the O2 not holding the heat in even though it's heated because of the headers pulling the heat out too quick. I just changed my t-stat and went back to 195 and it got a tad better but still not great. Maybe I should heat wrap the O2??
  1. tune vs no tune. safe?
    By hollas13 in forum General Grand Prix Discussion
    Last Post: 07-09-2013, 07:54 AM
  2. Canned tune question
    By hockeybawler in forum PCM Tuning
    Last Post: 02-26-2013, 08:44 AM
  3. Egr tune out Question
    By mcsddd in forum General Tech Discussion
    Last Post: 06-09-2012, 03:09 PM
  4. help!14.6@ my tune, 14.4@ stock tune w/genV+
    By Brooks in forum PCM Tuning
    Last Post: 08-16-2010, 06:16 AM
  5. Custom tune question
    By Bakerdd in forum General Tech Discussion
    Last Post: 08-11-2009, 03:17 PM
