Thread: Just bought HPT and would like some suggestions to help me fix my idle
Results 1 to 20 of 28
  1. #1 Just bought HPT and would like some suggestions to help me fix my idle
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    I had my car tuned by a "pro" but cant seem to get the idle right I was wondering if I post a screen shot of the settings someone could take a look and point me in the right direction.. As of now I dont plan to change anything other than that and take 1* of timing away, I have a lot of reading and learning ahead of me..
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  2. #2 Re: Just bought HPT and would like some suggestions to help me fix my idle
    Get on the HPT forums aswell if you can.
    Posting your file or scan on there is easy, you can get feedack from there aswell.
    Whats wrong with your idle though?
  3. #3 Re: Just bought HPT and would like some suggestions to help me fix my idle
    Arizona
    Just read your build page. Ensure your tune has the proper data for your 60lb injectors that may be your issue for the idle
    http://www.3800pro.com/forum/pcms-tu...r-scaling.html
  4. #4 Re: Just bought HPT and would like some suggestions to help me fix my idle
    Feb 2009
    flintnasty MI
    ^^Dont attempt to adjust offsets. They dont work on 3800 pcms.
  5. #5 Re: Just bought HPT and would like some suggestions to help me fix my idle
    Apr 2012
    Middletown DE
    once I get it tomorrow Ill upload the file and try to get a 30 minute log to post.
    1993 Oldmobile 88
  6. #6 Re: Just bought HPT and would like some suggestions to help me fix my idle
    Arizona
    Why would you not want the proper injector data since the op upgraded?
  7. #7 Re: Just bought HPT and would like some suggestions to help me fix my idle
    Apr 2012
    Middletown DE
    I also have more than idle issues.
    -flat spots
    -KR at shift points
    -random 4* of KR after 100mph
    -lean conditions at cruise (65ish MPH) 17.0+ AFR
    -goes lean around 25mph to the point it starves for fuel and stalls I monitor with the AEM UEGO when this happen the gauge just reads - - - no numbers
    1993 Oldmobile 88
  8. #8 Re: Just bought HPT and would like some suggestions to help me fix my idle
    Arizona
    Quote Originally Posted by acidcrashdburnd View Post
    -flat spots
    -KR at shift points
    Post the tune file use something like Google docs or cloud to up load it
  9. #9 Re: Just bought HPT and would like some suggestions to help me fix my idle
    Apr 2012
    Middletown DE
    Quote Originally Posted by 91parkave View Post
    I will have it up tomorrow, thanks.
    1993 Oldmobile 88
  10. #10 Re: Just bought HPT and would like some suggestions to help me fix my idle
    Feb 2009
    flintnasty MI
    all of these symptoms are mechanical, not tune related.
  11. #11 Re: Just bought HPT and would like some suggestions to help me fix my idle
    Apr 2012
    Middletown DE
    What could be wrong? no leaks before maf, clean maf, new o2, no exhaust leaks.
    1993 Oldmobile 88
  12. #12 Re: Just bought HPT and would like some suggestions to help me fix my idle
    Apr 2012
    Middletown DE
    It just occurred to me that I am running a stock pump with stock wiring. I will hook a gauge up to the car and do a few WOT runs friday night and see what I get; I would also like to tap in to the wiring if i can and monitor voltage for spikes and drops.
    Darkhorizon might be right.
    1993 Oldmobile 88
  13. #13 Re: Just bought HPT and would like some suggestions to help me fix my idle
    Arizona
    60 pound injectors with no pump upgrade? I assumed you took care of that....don't even bother at least rewire your fuel pump and order a 255lph pump
  14. #14 Re: Just bought HPT and would like some suggestions to help me fix my idle
    Apr 2012
    Middletown DE
    I am looking for a pump on the intense racing web site and found this,
    INTENSE Racing: Walbro 255lph Fuel Pump
    I cant find a pump listed for 04+
    1993 Oldmobile 88
  15. #15 Re: Just bought HPT and would like some suggestions to help me fix my idle
    Feb 2009
    flintnasty MI
    the tables unlocked in HPT are not injector offset tables as we understand them. I have experimented with them quite a bit and the effectively do nothing but cause the injectors to do very strange things.
  16. #16 Re: Just bought HPT and would like some suggestions to help me fix my idle
    Apr 2012
    Middletown DE
    1993 Oldmobile 88
  17. #17 Re: Just bought HPT and would like some suggestions to help me fix my idle
    I need to do a rewire on mine. I have one in the garage just haven't had anytime to do it. I don't have a problem with leaning out though.
  18. #18 Re: Just bought HPT and would like some suggestions to help me fix my idle
    Found one problem quickly, you are commanding 11.7 AFR, yet still having the ADD vs RPM table active. So its adding more and more and more fuel as the time goes on. If you are seeing 10 AFR I wouldnt be suprised.
  19. #19 Re: Just bought HPT and would like some suggestions to help me fix my idle
    Apr 2012
    Middletown DE
    First thing I adjusted, was adding 50rpms to the AC on field
    I am using this http://www.grandprixforums.net/hptun...ies-43620.html
    But I think its out dated.. I cant find some of the things mentioned.
    1993 Oldmobile 88
  20. #20 Re: Just bought HPT and would like some suggestions to help me fix my idle
    Apr 2012
    Middletown DE
    Which view can I see this in?
    1993 Oldmobile 88
  1. Rough Idle with intermittent idle miss
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2012, 12:12 PM
  2. Won't idle; missing above idle if you can get it started
    By jrece in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2011, 11:24 PM
  3. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  4. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
