Thread: Just bought HPT and would like some suggestions to help me fix my idle
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #1 Re: Just bought HPT and would like some suggestions to help me fix my idle
    Under fuel > power enrich.
    The Base AFR vs ECT is what the car will command for an AFR at WOT.
    The ADD vs RPM is just below it, that table will continue to increase the fuel amount based on rpm and time in PE mode.
  2. #2 Re: Just bought HPT and would like some suggestions to help me fix my idle
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    annd this is all i see..
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  3. #3 Re: Just bought HPT and would like some suggestions to help me fix my idle
    I shoulda said go to Engine > Fuel > power enrich.
  4. #4 Re: Just bought HPT and would like some suggestions to help me fix my idle
    Apr 2012
    Middletown DE
    Yeah I just found that, any instruction on how to adjust that?
    1993 Oldmobile 88
  5. #5 Re: Just bought HPT and would like some suggestions to help me fix my idle
    If you want to keep you WOT AFR at 11.7 or close to that, you will have to zero out the entire ADD vs RPM table.
    That way the car will try to stick to the Air fuel ratio that you want it at.
  6. #6 Re: Just bought HPT and would like some suggestions to help me fix my idle
    Apr 2012
    Middletown DE
    Awesome. I will try that out and add it where it needs it, if it needs it.
    I need to figure out timing, I was told that her added 2*
    1993 Oldmobile 88
  7. #7 Re: Just bought HPT and would like some suggestions to help me fix my idle
    Arizona
    Make sure sure in advanced mode.
    Then you need to make your fuel trims get in the park.
    Next I'd load a factory timing table in for low and high and run like that till its satisfied
    Rinse and repeat it would also be benfecial if you post your scan and config so we can see whats happening
  8. #8 Re: Just bought HPT and would like some suggestions to help me fix my idle
    Apr 2012
    Middletown DE
    I've been playing with the tune for a few days and the WOT tune is great now with the advice from fivefingerdeathpunch But still working on the seeking and stalling idle issue.
    https://www.dropbox.com/s/vuwvbjk8hg...Kyle%20GTO.hpt
    Thats a stock tune for a 2005 GTO, It my friends car I figured someone might want to see how different it is than our cars. The only thing I changed on his car was the fan on at key off settings to cool it down a bit
    1993 Oldmobile 88
  1. Rough Idle with intermittent idle miss
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2012, 12:12 PM
  2. Won't idle; missing above idle if you can get it started
    By jrece in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2011, 11:24 PM
  3. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  4. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
