1998 Grand Prix GT; 205.9k miles
I can usually let the car sit all day or overnight (to cool off?), it will then start, and run great for about 15 minutes. After that, it requires quite a few attempts with some accelerator to get it running again (without waiting overnight). It's firing on every key turn. It usually takes a little accelerator to keep it running. TRAC off light comes on at random times while trying to get it started.
Only one current DTC before starting troubleshooting below: P0141. Scanner reported no freeze frame data available.
I can post FSC stored DTCs if necessary. If memory serves one was some sort of O2 low voltage, another was P0300, random misfire, and I can't recall the third at the moment.
What I've done:
- Cleaned out clogged up EGR valve and replaced gasket
- Replaced plug wires
- Pulled each plug wire and ensured spark from each coil terminal
- Cleared DTCs
- Cleaned battery terminals and chassis ground; suspected chassis ground was disappearing causing the engine to die
- Temporarily removed front O2 sensor to create exhaust leak in case catalytic converter was an issue
- Replaced fuel pressure regulator
- Replaced IAC valve due to heavy buildup and showing shorted with DMM
- Removed and cleaned MAF sensor with MAF cleaner
- Removed throttle body and cleaned with carb cleaner
- Looked into upper intake and observed what appeared to be deformed (melted) plastic near the back side of the plenum. Upper intake was replaced at approximately 110k miles.
- Replaced Crankshaft position sensor
- Rescanned at various points with no DTCs being set. Scanner reports no freeze frame data available.
- Checked fuel pressure at various points; pulls down very near 40psi when starting, recovers to 48psi when it starts, and then returns to 43psi while the car idles. This is all within the first 15 minutes of cold start. I' m not seeing any difference in fuel pressure when it won't start.
I'll post more if I recall additional steps that were performed in trying to fix this car.
Thanks in advance for any assistance.
JR
