You will either need to live with the SES light for the cat, or you will need to stop the cat diagnostic test. Otherwise, the car will run rich while cruising.
HPT doesn't have the ability to remove the test unless they added it since they updated to 2.23.
I actually have the newest version, which is 2.24, but honestly have not looked at the program since downloading his stock tune so I could license his VIN.
But, I was going by this:
http://www.grandprixforums.net/remov...ml#post1032043
Found in the top sticky on this section. It looks like I can have the sensor functioning, but simply turn off the SES light and it would do the CAT test once, fail, then ignore. Is that not right? or am I still fuzzy on that whole 9 page thread?
Quote Originally Posted by blueguy View Post
Something else to change in there...which is simple...
Fan turn on points...have them kick on way sooner. Keeps things quite a bit cooler.
Yes. That will definitely be done. Don't have my truck's fan temps on this computer at work, but I will set them at the same temps as it is, which has worked well. Thanks.
Thanks for the link. If what I asked above is not going to work, then I guess this will be the next option.
