Thread: Any Newbie to GTP tuning tips, as far as what NOT to do??
Results 1 to 20 of 46
  1. #1 Re: Any Newbie to GTP tuning tips, as far as what NOT to do??
    May 2008
    Schuyler, NE
    You will either need to live with the SES light for the cat, or you will need to stop the cat diagnostic test. Otherwise, the car will run rich while cruising.
    HPT doesn't have the ability to remove the test unless they added it since they updated to 2.23.
  2. #2 Re: Any Newbie to GTP tuning tips, as far as what NOT to do??
    Omaha, NE
    Or use this http://shop.zzperformance.com/store/...-Emulator.aspx
  3. #3 Re: Any Newbie to GTP tuning tips, as far as what NOT to do??
    Apr 2013
    Baltimore
    I actually have the newest version, which is 2.24, but honestly have not looked at the program since downloading his stock tune so I could license his VIN.
    But, I was going by this:
    http://www.grandprixforums.net/remov...ml#post1032043
    Found in the top sticky on this section. It looks like I can have the sensor functioning, but simply turn off the SES light and it would do the CAT test once, fail, then ignore. Is that not right? or am I still fuzzy on that whole 9 page thread?
    Quote Originally Posted by blueguy View Post
    Something else to change in there...which is simple...
    Fan turn on points...have them kick on way sooner. Keeps things quite a bit cooler.
    Yes. That will definitely be done. Don't have my truck's fan temps on this computer at work, but I will set them at the same temps as it is, which has worked well. Thanks.
    Thanks for the link. If what I asked above is not going to work, then I guess this will be the next option.
    BOB
    2001 Gran Prix GTP Special Edition
    1971 Chevelle SS 402
  4. #4 Re: Any Newbie to GTP tuning tips, as far as what NOT to do??
    May 2008
    Schuyler, NE
    Quote Originally Posted by PeezDaddy View Post
    I have never checked to be sure that actually works. I don't think it does, but it would be worth a try.
  5. #5 Re: Any Newbie to GTP tuning tips, as far as what NOT to do??
    Feb 2009
    flintnasty MI
    doesnt work.
    You will need to hijack a tinytuner file into HPT, which isnt hard to do when you are stock assuming you can find a tinytuner file with the same OSID as you had unlocked. I could help map a file that is not supported if you are really hell bent on making it work in tinytuner.
  6. #6 Re: Any Newbie to GTP tuning tips, as far as what NOT to do??
    Apr 2013
    Baltimore
    Where would I "hijack" a TinyTuner file at?
    BOB
  1. Dual tips or trapezoid tips?
    By GTLGDP in forum Visual/Body Modifications
    Last Post: 01-19-2012, 11:42 PM
  2. tuning
    By nicksilvergt99 in forum General Tech Discussion
    Last Post: 08-30-2009, 05:40 PM
  3. Replies: 5
    Last Post: 05-11-2008, 07:10 PM
  4. Newbie questions on tuning
    By DesQ27 in forum Off Topic Discussion
    Last Post: 05-07-2008, 08:42 AM
