Thread: Torque management
Results 1 to 13 of 13
  1. #1 Torque management
    GTP Level Member apierce1289's Avatar
    United States
    Hey guys I was wondering what the benefits/negatives of removing torque management will be I currently have an overkill PCM and I want to completely remove torque management with my HP Tuners software. Also is there anyway I can get quicker shifts with HP Tuners or do I need to buy a shift kit?
    Sent from my DROID RAZR using Xparent Red Tapatalk 2
    Gremlins always seem to show up in pairs, or groups of three with our cars...
  2. #2 Re: Torque management
    You can reduce the shift time in the PCM, but you likely wouldnt notice a huge difference and its really not needed.
    Removing all of TQ MGNT is not a good idea. It is there to help protect the car unless otherwise built up to handle it.
  3. #3 Re: Torque management
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    I hear that removing torque management completely is equivalent to strapping an explosive to it that's set to detonate upon the accelerator being pressed.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  4. #4 Re: Torque management
    United States
    I don't want to kill my car. Overkill trans **** shifting just aren't exciting anymore. I want a 100% sport feel but not kill it.
  5. #5 Re: Torque management
    Newnan, GA
    Shift kit is probably the way to go. What your looking for is out of the stock parts range.
  6. #6 Re: Torque management
    May 2008
    Schuyler, NE
    What year is your car?
    Hard shifts break parts.
  7. #7 Re: Torque management
    United States
    2002 gt
  8. #8 Re: Torque management
    Arizona
    You can drop down to .125 on shift times and as stated above on the trans tables don't remove tourqe management but you can always modify TM. I took out about 65% of it on my tune.
  9. #9 Re: Torque management
    May 2008
    Schuyler, NE
    Leave it in there. You won't notice much of a difference anyways.
  10. #10 Re: Torque management
    Newnan, GA
    I would assume that Will has already done the PCM side of the shifting since OP already has an overkill tune.
  11. #11 Re: Torque management
    Banned
    Jan 2013
    Colorado
    How much of a difference in track times do you think it would make?
  12. #12 Re: Torque management
    Newnan, GA
    Very little to all of a sudden huge.
  13. #13 Re: Torque management
    May 2008
    Schuyler, NE
    You might be able to run .03 faster in the 1/4.
  1. Replies: 5
    Last Post: 05-18-2011, 04:20 PM
  2. Torque management What is it?
    By JoshsGTP in forum General Tech Discussion
    Last Post: 06-27-2010, 08:21 AM
  3. Replies: 18
    Last Post: 12-11-2009, 11:22 AM
  4. removing torque management
    By tjvdubsport in forum General Tech Discussion
    Last Post: 06-19-2009, 12:35 PM
  5. Replies: 5
    Last Post: 05-12-2008, 01:51 AM
