To Keep stock, +3 degrees timing,random missfire and evap ? I have light mods on my 02 GTP, 3.5 pulley,wbody catless down pipe, jmb intake, 180 stat,104's Thanks.
Don't need 3* of timing.
You don't have a cam, why do you need the P0300 removed?
Unless you deleted all the EVAP, then you don't need that removed either.
Being an '02 you also need the rear o2 sensor so leave that alone if you haven't messed with it already.
Ok thanks. Dwn pipe is 02 delete so il have to have that disabled.
But you need the rear o2...did I not say that?
Because Pat, people don't listen.
Don't be a d*ck , I'm on here to Learn. The rear 02 to me means the 02 farthest to the rear of the car.which will not be there when I put catless downpipe in.
I'm not sure who Mike contracts for his PCM's, but you should ask him if he can remove the cat diagnostic test. If they can't do that, you will probably need to keep your rear O2 sensor.
Theres also someone to cut your grass,clean your house, clean your pool ,I have never taken my PCM out. So much for your listening theory. It all comes done to $, I'm not loaded like you.
Uhhhh.....what?
If u have the cash anything can be done for u.
What does that have to do with what I said? I just told you to check with Mike if they can remove the diagnostic test.
If they cant remove the diagnostic test, you will FAIL emissions, EVERY time, no matter what you do. The rear o2 MUST either be there and working properly, or the code AND the diagnostic test deleted. From what I hear an o2 simulator wont do the trick either.
There's a reason they said you need that rear o2.
JT200... Whatever... There are a few simple rules in life.
One is.. You GOTTA pay if you wanna play!
Two is... Don't spit in the wind!
The moral of the story here is nothing is for free. You want to start modding you car, it's going to cost you. Maybe you should've left it stock, then you'd not have to worry about anything like deleting the rear O2 from PCM.
Which if you bothered to research, (answer would've been here). Most economical thing to do that'll save you money in long run is to (answer would've been here).
So, don't expect help when you're being what you say others shouldn't!
Have a nice day!
I apologize, Miss interpreted, thought u meant some kind of electronic scan tune.
No i didn't realize that, thought it was a couple hundred dollars for that
