Thread: which torque management table to retard timing at shifts?
Results 1 to 6 of 6
  1. #1 which torque management table to retard timing at shifts?
    Someone refresh my memory on which torque management table-under fuel, spark, tranny where you set how much timing to retard at the shifts? On the tranny take I have the bottom portion from 18step ft/lb to 32 step ft/lb at 13% for the 2-3 upshift, but when I go out and do a wot I still don't see the car pulling timing. This is via powrtuner. Tia
  2. #2 Re: which torque management table to retard timing at shifts?
    Which Tunnnnaaaaa?
  3. #3 Re: which torque management table to retard timing at shifts?
    sorry dhp powrtunaa
  4. #4 Re: which torque management table to retard timing at shifts?
    Doggy Horse Powah... Hmmm I'm thinking I remember that under the area of TQ Mgmt, doesn't DHP have a section just for that?
  5. #5 Re: which torque management table to retard timing at shifts?
    well they have it under fuel, spark, and transmission sections
    like mentioned i increased the percentage under the tranny folder starting from the 22ft/lb step to 32ft/lb step 8% ro 13% but did not notice any sigsn of the pcm retarding more timing at the 2-3 upshift. so curious if im missing something?
  6. #6 Re: which torque management table to retard timing at shifts?
    Florida
    under transmission / Torque Mgmt / Max_Engine_Torque_For_Upshift
  1. Torque management What is it?
    By JoshsGTP in forum General Tech Discussion
    Last Post: 06-27-2010, 08:21 AM
  2. Actual Timing > Spark Table
    By JoshMcMadMac in forum PCM Tuning
    Last Post: 10-09-2009, 06:49 AM
  3. removing torque management
    By tjvdubsport in forum General Tech Discussion
    Last Post: 06-19-2009, 12:35 PM
  4. Can't get timing to match table values!??!
    By DanGTP in forum PCM Tuning
    Last Post: 10-25-2008, 11:45 PM
  5. Replies: 5
    Last Post: 05-12-2008, 01:51 AM
