Thread: Hp tuner noob question?
Page 1 of 3 123 LastLast
Results 1 to 20 of 50
  1. #1 Hp tuner noob question?
    Jun 2012
    Grantville, Ga
    I am new to this tuning stuff. I have been fallowing Gary's tuning guid i got from Full throttle v6. i am at the point where i am tuning wiht the ltft but my wide band is at 10.8 most of the time. how do i lean the tune out as a whole to get it up to 12.5 to 13?
  2. #2 Re: Hp tuner noob question?
    You can try getting the LTFT within +/- 3 of 0% by doing a MAF tune.
    I would get a fuel pump rewire and set up your injector table so that all are the same and then see what its saying.
    Then you can take away fuel via the MAF.
    11.4-11.5 AFR is about perfect for a supercharged car. Read up on tuning info on this site. I can say I've never really followed Gary's tuning ways.
  3. #3 Re: Hp tuner noob question?
    Jun 2012
    Grantville, Ga
    have tried on two computer and the files are to big.
  4. #4 Re: Hp tuner noob question?
    Jun 2012
    Grantville, Ga
    The run down of the vehicle is a 88.5 suzuki samurai with a 98 s/c 3800. their is no egr, evap or cats on the zuk. As far as the pcm goes it thinks it stock with no trans. I do have a 2005 s/c on the top of it. http://s1203.photobucket.com/albums/...t=IMG_0556.mp4
  5. #5 Re: Hp tuner noob question?
    When you say "files too big", what are you talking about?
  6. #6 Re: Hp tuner noob question?
    Out West
    Quote Originally Posted by Quarterpastgone View Post
    Even the N/A cars don't run that lean WOT.
    I've experimented with mid 12's AFR on a big pulley with some mods before. It's not that great honestly.
    11.0 is the target you wanna hit if you're not cammed or intercooled.
    mid 11's is great if you're either or, however.
    Whine with your Cheese?
  7. #7 Re: Hp tuner noob question?
    Jun 2012
    Grantville, Ga
    the atacment software will not let me upload the files to it to attach. As far as AFR goes i was shooting for a little leaner to help with mpg some. But i wil see how that goes with the whole tuning proccess matures on this project.
  8. #8 Re: Hp tuner noob question?
    Ahhh load it to something like scandepot or one of those sites.. then link
  9. #9 Re: Hp tuner noob question?
    Out West
    top end AFR leaning won't help mpg unless you're 10.5 or lower and manage to work out a full point to 11.5 or so
    timing tuning will help, driving less aggressively will help as well.
  10. #10 Re: Hp tuner noob question?
    Jun 2012
    Grantville, Ga
    I agree with both timing and less agressive driving. With that said i am getting 14.9 mpg right know and that is will very easy driving. I tuned the first time by my short term fuel trims and had the timing advanced 6 degrees and was getting 1 to 2 kr every know and then. I think i have my VE table close know and will be hooking my MAF back up tonight and go from there. WB is from 9.8 to 10.8 most of the time. I figured if i get it to 11.5 it would help some at least.
  11. #11 Re: Hp tuner noob question?
    Out West
    That's kinda pathetic....
    On the worst of traffic days still romping on it, both the GP and the Regal never went below 16-17 avg..
    You need to show us a good set of logs and your current tune.
  12. #12 Re: Hp tuner noob question?
    14 is pathetic. If you follow the info of starting hpt here in the pcm scection...you'll have it doing much better with one maf iteration.
  13. #13 Re: Hp tuner noob question?
    Jun 2012
    Grantville, Ga
    The sad part is this thing is under 3000lb too. here is a link to the build of the Beast
    Zoyovy Build - Zukikrawlers
  14. #14 Re: Hp tuner noob question?
    Jun 2012
    Grantville, Ga
    Here is teh tue and last log from earlier today. tune first and scann second
    http://uploading.com/files/get/91df9...%2Bmaf%2B1.hpt
    http://uploading.com/files/get/432322d7/MAF%2B1.hpl
  15. #15 Re: Hp tuner noob question?
    Why is your PE enable set to 100%? I wouldn't get on it much at all without that enabled.
    Your MAF tune needs a lot of work looking at those LTFT's.
    Your font O2 sensor is cycling quite well most of the time.
    Is the WB showing ~10 even when the front O2 sensor is cycling?
    If so, either the wide band is crap or the install is faulty in some way, likely the former, or your narrow is shot or not reading correctly.
    One or the other.
  16. #16 Re: Hp tuner noob question?
    Jun 2012
    Grantville, Ga
    The PE table from what j have read is to be set at 100% on multiple forums, here and on hp tuners. As far as the wideband goes it reads the same in hp tuners and with a ddm. From what I can see by the install it is right. The short band is also new and is right from what I can tell. If the long terms ad with in 20 it can keep up. I am new to tuning but as far as the rest it all checks good.
    If pe enable is set to 100% you should never go wot. Especially if this is blown.
    Is it possible to log your wb as well?
  18. #18 Re: Hp tuner noob question?
    Jun 2012
    Grantville, Ga
    My wideband is histo 6 in the scans, as far as wot i have not started tuning for wot just yet i am tuning for regular driving at this point.
  19. #19 Re: Hp tuner noob question?
    Jun 2012
    Grantville, Ga
    Download zuyovy maf 4.hpt for free on uploading.com tune
    Download MAF 4.2.hpl for free on uploading.com scan
    i must be missing something doing this, while driveing at 70 to 80, 2200 t0 2400 rpm why does this thing go so rich at this rpm range. I keep tunignthe maf but dont know if that is the best way to go about it.
  20. #20 Re: Hp tuner noob question?
    Just like I suspected, either your NB or your WB is off.
    Your NB is flipping back and forth while the WB is reading rich.
  1. noob with a question
    By skinner in forum Introductions/Noob Questions
    Last Post: 10-18-2012, 11:11 AM
  2. Noob question
    By TheWizard in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2011, 04:41 PM
  3. noob question
    By GTP Ryan in forum Off Topic Discussion
    Last Post: 10-15-2010, 11:41 PM
  4. Noob Question
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 07-13-2010, 10:30 PM
  5. noob question....
    By OhsoKleaN in forum Tires & Wheels
    Last Post: 02-08-2010, 02:32 PM
