Thread: PCM Troubles. Anybody run into this issue before?
Results 1 to 18 of 18
JesseSmash PCM Troubles. Anybody run... 10-16-2012, 08:52 PM
Fivefingerdeathpunch Re: PCM Troubles. Anybody run... 10-16-2012, 08:57 PM
JesseSmash Re: PCM Troubles. Anybody run... 10-16-2012, 09:09 PM
JesseSmash Re: PCM Troubles. Anybody run... 10-16-2012, 09:02 PM
Fivefingerdeathpunch Re: PCM Troubles. Anybody run... 10-16-2012, 09:04 PM
BillBoost37 Re: PCM Troubles. Anybody run... 10-17-2012, 06:20 AM
jteske88 Re: PCM Troubles. Anybody run... 10-17-2012, 08:40 AM
coolone Re: PCM Troubles. Anybody run... 10-17-2012, 08:55 AM
JesseSmash Re: PCM Troubles. Anybody run... 10-17-2012, 11:27 PM
JesseSmash Re: PCM Troubles. Anybody run... 10-18-2012, 01:32 AM
BillBoost37 Re: PCM Troubles. Anybody run... 10-18-2012, 05:44 AM
Anthony Smith Re: PCM Troubles. Anybody run... 10-18-2012, 09:21 PM
JesseSmash Re: PCM Troubles. Anybody run... 10-19-2012, 12:42 AM
BillBoost37 Re: PCM Troubles. Anybody run... 10-19-2012, 06:52 AM
JesseSmash Re: PCM Troubles. Anybody run... 10-19-2012, 11:16 PM
JesseSmash Re: PCM Troubles. Anybody run... 10-19-2012, 08:28 PM
BillBoost37 Re: PCM Troubles. Anybody run... 10-22-2012, 07:27 AM
coolone Re: PCM Troubles. Anybody run... 10-22-2012, 08:27 PM
  1. #1 PCM Troubles. Anybody run into this issue before?
    Aug 2012
    Saskatoon, SK, Canada
    Sooooo I swapped my battery out because, well, it sucked. Then, I went and reduced the sensitivity of my shock sensors because I grew tired of my stock alarm system going off for no reason.
    A couple days later, I enter my car and everything is dead. Power locks won't work, interior lights won't come on, and worse yet, nothing happens when I turn the key. Even though it's a brand new battery, I measure the voltage anyway and get an even 12.5 V with no jumping around. My friend suggests I leave the + terminal disconnected for 10 min. to reset the PCM. I do this, and sure enough it starts up no problem.
    This morning as I'm leaving, my stereo pops, everything cuts out, and my engine stalls. I restarted it and made it to work. Then at work when I get in at lunch, the power locks work, dash lights come on, but when I try to start it, the starter starts to engage for a split second then everything cuts out. Again, I disconnect the battery and she starts up a little later, though a little rougher than normal.
    On the way home I monitored my running voltage, which hung around 13.9 and dropped very briefly to 13.7 when stopped.
    Back at home, I go to start my car. Everything works. Try to turn over the engine and EVERYTHING cuts out. No lights or anything come back on. Everything is dead. Disconnected the battery yet again, and she's sitting like that til morning.
    I'm thinking my PCM is screwed. Which is a good excuse to get a tuned one.
    If you don't think it's my PCM, let me know so I can put the money towards resolving this issue.
    If you think it is my PCM, what version is the best bang for your buck? I don't plan on getting too fancy - intake, smaller pulley, and exhaust is all I want at the moment. So ZZP? Wbodystore? Overkill? Other? I'm leaning towards Overkill since I am in Canada.
    Thanks.
  2. #2 Re: PCM Troubles. Anybody run into this issue before?
    I doubt its your PCM.
    You have some sort of wire issue going on here, I like to blame aftermarket alarms.
  3. #3 Re: PCM Troubles. Anybody run into this issue before?
    Aug 2012
    Wasn't when I opened the door. As for after it was running, I didn't look. But it was doing the honks that I know so well from when it would go off in the middle of the night.
  4. #4 Re: PCM Troubles. Anybody run into this issue before?
    Aug 2012
    Don't have an aftermarket alarm. Completely stock. Did put in a new stereo, but I checked the wiring today. It's all fine. Plus this issue started before I put in the new stereo.
    Another thing I forgot to mention. After the first day it happened, I unlocked my car. The factory alarm disarmed, I started it and the %$%#% factory alarm started going off. i hit the unlock button on the key fob and it stopped honking.
  5. #5 Re: PCM Troubles. Anybody run into this issue before?
    Security light flashing?
  6. #6 Re: PCM Troubles. Anybody run into this issue before?
    What are you driving?
  7. #7 Re: PCM Troubles. Anybody run into this issue before?
    Yoga city
    i would check for a grounded lead wire to rule out a wiring job.
  8. #8 Re: PCM Troubles. Anybody run into this issue before?
    Nov 2011
    NY
    More info please. Year make n model. Any aftermarket installs, such as autostart etc. Any work done recently...
  9. #9 Re: PCM Troubles. Anybody run into this issue before?
    Aug 2012
    1998 Pontiac Grand Prix GTP. Nothing aftermarket at all. All this happened after I switched out the battery and reduced the sensitivity of the alarm using the method outlined in the owner's manual.
    Most recent work would be front rocker gasket, supercharger oil change, and wheel alignment.
    Threw a code for the EGR valve recently.
    Car is completely dead today.
  10. #10 Re: PCM Troubles. Anybody run into this issue before?
    Aug 2012
    Oh also new halo headlights.
  11. #11 Re: PCM Troubles. Anybody run into this issue before?
    Ok, power for locks, seats, headlights.. none of that goes through the pcm. Pretty sure we can rule it out. All this power and control of these various things does go through the BCM or body control module.
    However...you appear to have a draw or other issue if you are finding the battery dead. I would double check that the the power cable from the alt is snug. Check the voltage etc of the battery, is it dead or is it just not supplying power to the car.
  12. #12 Re: PCM Troubles. Anybody run into this issue before?
    Apr 2011
    Vassar, Mi
    my guess would be corroded battery cables or bad terminals in the new battery. I also guess that unhooking the batt cables isnt resetting anything its just getting a working connection to the battery again when you reconnect them. Try to wiggle the cables when its acting up and see if it works or try a different battery.
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  13. #13 Re: PCM Troubles. Anybody run into this issue before?
    Aug 2012
    Battery is not dead. I cleaned the terminal out and the bolt off as well because it was corroded. I have tried wiggling the cables but I will try again more thoroughly.
  14. #14 Re: PCM Troubles. Anybody run into this issue before?
    If you had enough corrosion to have needed to clean it. Next time you pull the cables. Take the bolt out and slide the rubber boot off. Is the crimp from the connector to the cable green and in questionable shape? it might be time for fresh cables.
  15. #15 Re: PCM Troubles. Anybody run into this issue before?
    Aug 2012
    I would like to let you know, sir, that you were 100% correct on this. The old battery was leaking acid everywhere and it corroded the connection to ****. A good cleaning and some baking soda and water seems to have resolved the issue.
    My friend took one look and diagnosed it before I even mentioned it to him. Looks like I learned something new today.
    Thanks for your help everybody. <-- That's me, embarrassed.
  16. #16 Re: PCM Troubles. Anybody run into this issue before?
    Aug 2012
    Didn't need to clean it, I decided to while I had it disconnected. But I will check the cables because it doesn't hurt to look.
  17. #17 Re: PCM Troubles. Anybody run into this issue before?
    Glad to hear you found it and got it straightened out.
    You realize..we only know this one, because it's likely happened to us.
  18. #18 Re: PCM Troubles. Anybody run into this issue before?
    Nov 2011
    NY
    +1,000! Lol...
  1. Engine troubles
    By illy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2012, 10:37 AM
  2. lot of troubles
    By crazymind in forum General Tech Discussion
    Last Post: 09-05-2012, 08:18 PM
  3. 96 GTP tranny troubles!!!
    By slcGTP in forum General Tech Discussion
    Last Post: 05-01-2010, 11:35 PM
  4. A/C Troubles, I'm all searched out.
    By JESSEGOTTA GP GT in forum General Tech Discussion
    Last Post: 04-17-2010, 04:58 PM
  5. Need some help with amp and sub troubles
    By Thunderturd in forum Audio, Security & Visual Electronics
    Last Post: 08-20-2009, 02:51 AM
