If you had enough corrosion to have needed to clean it. Next time you pull the cables. Take the bolt out and slide the rubber boot off. Is the crimp from the connector to the cable green and in questionable shape? it might be time for fresh cables.
I would like to let you know, sir, that you were 100% correct on this. The old battery was leaking acid everywhere and it corroded the connection to ****. A good cleaning and some baking soda and water seems to have resolved the issue.
My friend took one look and diagnosed it before I even mentioned it to him. Looks like I learned something new today.
Thanks for your help everybody. <-- That's me, embarrassed.
