Thread: Tuning trans question / Major WOT problem
Results 1 to 4 of 4
  1. #1 Tuning trans question / Major WOT problem
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    I did a bunch of searching and I wasn't able to find answers for this so I thought I would ask. When tuning part throttle shift its pretty self explanatory but whats the relationship between wot shift speed and wot shift rpm? Should they match up? Which one does the pcm actually use or does it use both? What happens when set grossly different? (4000rpm shift at 70mph or 7000rpm shift at 20mph).
    The other question I had, which might be related to my first question, is what could be causing my car to cut out whenever playing with wot shift speeds / rpm above stock? It feels almost like fuel / spark cutout but both of my limiters are set to 7k so it isnt that. It only happens right at the top of the gear right before the shift and it gets worse whenever I raise my WOT shift rpm to the point that the car cant even reach the shift point if set high enough! Its not a gradual thing its like it hits a brick wall. This is on a 2001 gt with mild porting on the lim, Hv3, PLOG, Catless Downpipe, Stage 1 tb, and rockers. My stock injectors are reaching 90% duty cycle so im on the verge of buying bigger injectors just so i can maybe shift at a decent rpm other then the crazy stock 5400 rpm shift!
    I am getting no kr either (Seems like my pcm ignores the high octane table? Never see it command more then my low octane table at wot?)
    Any help would be greatly appreciated! This thing is getting supercharged soon so I need to figure this out!
  2. #2 Re: Tuning trans question / Major WOT problem
    For shifting, it wants to meet both speed and rpm. Some folks set the speed to 0 so that it's always met and then use the rpm to command the shift. Or you can figure out where both happen.
    Check your injector disable table, you may be hitting a torque or power limiter that is pulling 3 of the cylinders power through the injector table.
  3. #3 Re: Tuning trans question / Major WOT problem
    Apr 2011
    South Dakota
    Thanks for the tips!
    As far as i can see I have all injector disable tables 0ed out. This is a base tune made by overkill so he has it all set up to just go pig rich and pull timing instead. I will try zeroing out the wot shift speed table and just set the rpm and see what happens. Do you know if theres a PID that I can scan that will tell me if the pcm is dropping injectors?
  4. #4 Re: Tuning trans question / Major WOT problem
    Out West
    I do just this. -- Set to 0 until i figure out exact speed vs rpm
    Whine with your Cheese?
  1. Major problem please help
    By Logan541 in forum General Tech Discussion
    Last Post: 07-30-2012, 10:08 AM
  2. Major work done....now having major problem
    By L36 Killer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-14-2012, 11:14 PM
  3. Major a/c problem
    By GrandPrix08Ky in forum General Grand Prix Discussion
    Last Post: 06-22-2012, 03:04 PM
  4. New to GTP and have major problem
    By phantom2 in forum Introductions/Noob Questions
    Last Post: 09-23-2010, 11:02 PM
  5. Help Major problem
    By Krazicustom in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-08-2009, 09:16 AM
