Thanks for the tips!
As far as i can see I have all injector disable tables 0ed out. This is a base tune made by overkill so he has it all set up to just go pig rich and pull timing instead. I will try zeroing out the wot shift speed table and just set the rpm and see what happens. Do you know if theres a PID that I can scan that will tell me if the pcm is dropping injectors?
