For shifting, it wants to meet both speed and rpm. Some folks set the speed to 0 so that it's always met and then use the rpm to command the shift. Or you can figure out where both happen.
Check your injector disable table, you may be hitting a torque or power limiter that is pulling 3 of the cylinders power through the injector table.
