Thread: Major a/c problem
Results 1 to 3 of 3
  1. #1 Major a/c problem
    Jun 2012
    Ky
    Replaced A/C Compressor, fan working well. A/C will only blow cold air with higher speeds, usually 45mph or higher. Blows warmer air with lower speeds and takes a LONG time to start cooling. ANY suggestions welcome.
  2. #2 Re: Major a/c problem
    head in for one of them free a/c checks you should be seeing all over these days, or check you levels, if you have gauges to do so.
    you can also clean the a/c condenser in front of the radiator. engine de greaser and a hose works.
  3. #3 Re: Major a/c problem
    Dec 2011
    Central New Joisey
    Did you replace the compressor yourself? if so, did you use a vacuum pump to draw the system down to a complete vacuum and let it sit for 15-20 min to make sure any air with moisture had boiled off? Thats the only way to be sure the system is fully purged of air and recharged fully.
  1. major power windows problem
    By doughboy0032 in forum General Tech Discussion
    Last Post: 11-05-2011, 09:44 PM
  2. New to GTP and have major problem
    By phantom2 in forum Introductions/Noob Questions
    Last Post: 09-23-2010, 11:02 PM
  3. 02 SE Major Electric Problem
    By rs2sensen in forum General Tech Discussion
    Last Post: 02-28-2010, 04:40 PM
  4. Help Major problem
    By Krazicustom in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-08-2009, 09:16 AM
  5. major own-age!
    By gtpinsc in forum Off Topic Discussion
    Last Post: 10-31-2008, 10:38 PM
