I have a canned zzp tune I'm starting with
Quote Originally Posted by Pure2sin View Post
You should really try UVscan instead of the logging in DHP.
Show a screen shot of your: Calibration data>Fuel>PE>Base_PE_AF
That would be where the main changes would be made but before you do anything post a screen shot.
Yeah two ways to go about this:
One: Change PE values in so that you see what you want on the WB.
Note: you may end up seeing some strange things like commanding 9:1 AFR or 13:1 AFR and getting 11.0 on the WB.
Two: Ensure fuel system is setup correctly. Then calibrate MAF so that commanded is the same as actual. Then pick a commanded AFR.
What do you mean by the fuel system being setup correctly? I appreciate the help guys I'm kinda lost right now lol
