Thread: How to lean a car out with DHP
Results 1 to 17 of 17
  1. #1 How to lean a car out with DHP
    I'm not sure what to change to lean my car out a little bit. Here is a log and my wb shows about 10.8 ish at wot
  2. #2 Re: How to lean a car out with DHP
    Sep 2011
    Southern Alberta, Canada
    usually the map sensor.
  3. #3 Re: How to lean a car out with DHP
    MAP?
    Oh buddy............
    Well first thing: do you have a canned tune?
  4. #4 Re: How to lean a car out with DHP
    Minnesota
    You should really try UVscan instead of the logging in DHP.
    Show a screen shot of your: Calibration data>Fuel>PE>Base_PE_AF
    That would be where the main changes would be made but before you do anything post a screen shot.
  5. #5 Re: How to lean a car out with DHP
    Yeah two ways to go about this:
    One: Change PE values in so that you see what you want on the WB.
    Note: you may end up seeing some strange things like commanding 9:1 AFR or 13:1 AFR and getting 11.0 on the WB.
    Two: Ensure fuel system is setup correctly. Then calibrate MAF so that commanded is the same as actual. Then pick a commanded AFR.
  6. #6 Re: How to lean a car out with DHP
    I have a canned zzp tune I'm starting with
    Quote Originally Posted by Pure2sin View Post
    What do you mean by the fuel system being setup correctly? I appreciate the help guys I'm kinda lost right now lol
  7. #7 Re: How to lean a car out with DHP
    Minnesota
    I think you need to do some MAF tuning.
  8. #8 Re: How to lean a car out with DHP
    No point in MAF tuning till you figure out the fuel.
    From the factory, fuel pressure drops off in boost compared to what it should be. Hence the oddly sloped injector flow rate table.
    If you get a fuel pump rewire, that should bring things back up to par. Then you'd run the values from 100 kPa vacuum in both IFR and offset vs pulsewidth vs MAP in all columns.
    Or you could just tune around all of that via PE and MAF tables.
    Whatever floats your boat.
  9. #9 Re: How to lean a car out with DHP
    What do I do to the maf to tune it. I'm sure I sound like a retard but I'm not sure what to do exactly. I'd like to figure this tuner out a little before I do any other major changes to the car.
  10. #10 Re: How to lean a car out with DHP
  11. #11 Re: How to lean a car out with DHP
    Thanks matt i guess i have a lot of reading to do lol. Does anyone know where i can dl tinytuners?
  12. #12 Re: How to lean a car out with DHP
    check the stickies in this section.
  13. #13 Re: How to lean a car out with DHP
    Will do. Research here I come.
  14. #14 Re: How to lean a car out with DHP
    So to do the open loop maf tuning i'd have to log my wb? I can't do that with dhp right?
  15. #15 Re: How to lean a car out with DHP
    Minnesota
    Yes you can. That is what that little green thing is on the side of the box is for. If you have one, but you should.
    Green part on the bottom of the box shown in this pic.
  16. #16 Re: How to lean a car out with DHP
    Which part of that do I hook it to and do I have to dl anything to make it work?
  17. #17 Re: How to lean a car out with DHP
    Feb 2009
    flintnasty MI
    Matt.. you are mistaken here.. that boob had no idea what he was talking about.
    Fuel pressure DOES NOT fall off from the factory... if it does then your fuel system went to ****.
    You dont need it.
    After PE and IFR is adjusted....
    10.8 is pretty solid for a 3.4 car.. but I would wiggle PE up and down to see if the KR gets worse or better... leaner is probably not going to be the direction you want to head.
  1. Im running too lean?
    By dmahlikGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-13-2011, 12:36 PM
  2. Running Lean
    By duneking905 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2010, 02:06 AM
  3. lean at idle
    By JayGTP02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-30-2010, 02:24 PM
  4. Lean?
    By Deeter in forum PCM Tuning
    Last Post: 09-17-2008, 05:11 PM
  5. 940 WOT o2 is lean?
    By Bio248 in forum PCM Tuning
    Last Post: 03-04-2008, 05:55 PM
