MAP in kpa/hqs or whatever, should be at -19ish, just like if you were to hook a vacuum gauge up to it.
Other way to tell is Fuel Trims.
Short term and long term, you want both to be around + or - 3-4ish.
If the long term fuel trim is pegged at 16.4 or higher than normal, you have a vacuum leak.
