Thread: MAP/MAF readings to detect a vacuum leak?
Results 1 to 3 of 3
  1. #1 MAP/MAF readings to detect a vacuum leak?
    Pennsylvania
    Just doing some thinking and wondering if this is possible. On my OBDII scanner I can see live engine data from the sensors, Im suspicious I have a vacuum leak from the plenum and I want to monitor how its doing for permanence after I fix it, instead of pulling the fuel rail over and over checking to make sure all the bolts are tight.
    Would having a vacuum leak from the plenum gasket (i.e. plenum bolts not torqued right) be noticable on MAP or MAF readings, since a vacuum leak there would change the manifold pressure, and the way I see it, having air coming in unmetered in another location would cause the MAF reading to be different than expected as a specific RPM, no? Or is my logic totally flawed?
    So provided that it is possible, what would a healthy value be for NA l26 at idle for the MAP and MAF sensors? ... hv3, plog, dp if that changes anything.
    Sport Edition Kv5 18x8
  2. #2 Re: MAP/MAF readings to detect a vacuum leak?
    MAP in kpa/hqs or whatever, should be at -19ish, just like if you were to hook a vacuum gauge up to it.
    Other way to tell is Fuel Trims.
    Short term and long term, you want both to be around + or - 3-4ish.
    If the long term fuel trim is pegged at 16.4 or higher than normal, you have a vacuum leak.
  3. #3 Re: MAP/MAF readings to detect a vacuum leak?
    Monitor your IAC. Reason being is that controls your idle via a "controlled" vacuum leak. Therefore it adjusts when you have a leak to keep the idle where the pcm is commanding it to be.
  1. Vacuum Leak Help
    By RichardL12 in forum General Tech Discussion
    Last Post: 06-03-2010, 06:28 AM
  2. vacuum leak or bad egr
    By mjdennis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2010, 10:49 PM
  3. vacuum leak?
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-02-2010, 01:27 PM
  4. vacuum leak
    By boredout in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-15-2008, 08:22 AM
  5. Bad vacuum leak
    By boredout in forum General Tech Discussion
    Last Post: 07-14-2008, 02:21 AM
