Thread: my input Aeroforce vs ScangaugeII
Results 1 to 7 of 7
  1. #1 my input Aeroforce vs ScangaugeII
    Florida
    Ok so saw in the chat box people were wondering about the scan gauge II.
    i have had one of the first aeroforce interceptors from like 2005! before all the more fancy add on's like case learn and triggering the fans. so the currant aeroforce gauge will be even better then the one i had.
    after 5 years of florida heat my aeroforce's screen got washed out and the wire on the display lifted off... so i took the opportunity to get a SG2. the preloaded PID's were fine but lacked fuel trims, KR, and trany temp. using the Xgauge feature, i added all of these... but never did get the KR to work... it very well could have been working as my tune was good.... but since it only showed 0 vs 0.0 of the Aeroforce i was unsure if i saw partial KR. the big difference i saw was the refresh/response rate. the SG2 was about half as fast as the aeroforce! both at the highest settings the aeroforce wins by a land slide.
    where the SG2 wins out on the aeroforce... color choices and being able to change them and that it displays 4 gauges at once and freeze frame data on SES's. but since the refresh was slow i feel it is only good for trany temp, fuel trims, and other data that doesnt move that much or isnt a major factor.
    I am sending my aeroforce in to have the screen replaced. the SG2 went to my wife's lancer.
    so that ends the FYI.
  2. #2 Re: my input Aeroforce vs ScangaugeII
    The Boss Iceman6669's Avatar
    Jun 2011
    Does the aeroforce also scan and clear OBDII codes? The SGII website says it comes loaded to read ignition retard. Is that not the same as KR?
    2011 F-150 Yote powered
  3. #3 Re: my input Aeroforce vs ScangaugeII
    Florida
    IM NOT A RETARD! im special lol.... ignition retard is not KR. yes even my old aeroforce the 1st generation would scan and erase OBD2 codes.
  4. #4 Re: my input Aeroforce vs ScangaugeII
    Pennsylvania
    [QUOTE=Z34Phoenix;666707ignition retard is not KR.[/QUOTE]
    whut
  5. #5 Re: my input Aeroforce vs ScangaugeII
    Florida
    Quote Originally Posted by Iceman6669 View Post
    Quote Originally Posted by SlowNA06 View Post
    whut
    Ignition retard on the SGII is not KR. when it would disply ign it would be timing advance.
  6. #6 Re: my input Aeroforce vs ScangaugeII
    Pennsylvania
    well, yeah. But retard is retard. (That is easily one of the weirdest things I've ever had to write)
  7. #7 Re: my input Aeroforce vs ScangaugeII
    SE Level Member Leiliel666's Avatar
    Mar 2012
    i got a scangauge 2 and the KR detector has me a tad bothered. at WOT in second gear it registers 0.0 all the way into 3rd on normal refresh. but on fast refresh it shows up to 9.4. id figure that with the sustained rpm in second gear that it would show it in normal if it was there. But the VPW protocol type OBD2 that was 2003 and before doesnt work well with fast scan so i may just be scaring myself
    4200 Stroker Kit, ZZP CAI, Plog and manifold kit, cross drilled slotted rotors, TVS custom S/C rotor swap, Modified SnakeBite Kit, Ported Heads, 1.9 Rockers, 4.0 Pulley 10.5 mm Wires, 160 Tstat, AL103, ZZP 1.0 PCM/tuned // 13.24 @ 106
  1. any input here
    By nicks98gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-07-2011, 08:20 PM
  2. need some input input input.(short circuit)
    By IR II IP IDEATH in forum 5.3L V8 (LS4)
    Last Post: 02-17-2010, 03:23 AM
  3. Who owns a ScanGaugeII?
    By dstout in forum General Tech Discussion
    Last Post: 03-27-2009, 06:55 PM
  4. Need input on set up!
    By GTP4 in forum PCM Tuning
    Last Post: 10-27-2008, 08:53 PM
  5. looking for input
    By fratzke7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2008, 09:47 PM
