Thread: overkill, zzp
Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
  1. #21 Re: overkill, zzp
    GT Level Member Overkill's Avatar
    Nanaimo British Columbia
    Paying what you would pay for a 2 box tunes (one now, one when you mod again) is going to run you the same if not more than used HPT with credits.
    Not true. Retunes are $50 through me, plus $25 shipping, and likely $25 to return ship to me, so say $100 a retune. You'd be on your 4th retune (5th tune overall) by the time you equal the price of purchasing a new HP Tuner software, nevermind the challenge of using it.
    Last I heard Overkill wasn't responding to messages.
    As mentioned, was on holidays!
    I also didn't realize my sponsorship of the site had run out, it was auto renewal the last few years? Responsored!
    Email all inquiries to willoverkill@gmail.com!
  2. #22 Re: overkill, zzp
    Texas
    Not really. Paying what you would pay for a 2 box tunes (one now, one when you mod again) is going to run you the same if not more than used HPT with credits. Plus being able to change with climate changes is also good.
    There's one problem. It takes time to learn how to tune and if someone has never done it before it's not something you just start messing with. Input the wrong values and you just blew your engine. It takes time to learn which parts to tweak. I personally would rather pay someone else who has the knowledge to do it right the first time. Than spend weeks or even months getting a tune just right. Less time tuning means more time to beat on the car and have a good time.
    85 Corvette
    01 TA
    03 Z06
  3. #23 Re: overkill, zzp
    Windsor (ON) Canada
    Car is a whole new machine since the tune (got it today).
    Thanks again Will
  4. #24 Re: overkill, zzp
    GT Level Member TheAce144's Avatar
    Dec 2010
    Montreal, Canada
    Quote Originally Posted by Colossus View Post
    Thanks again Will
    Just came back from east of Toronto, got a custom street tune by Will. I am amazed by the results, car has never run so great, crazy throttle response, ridiculously good mpg...just wow.
    Thanks again Will! I shall write a review about the great experience on the forums. Take care!
    -Charles V
    04 GTP CompG: SSAC Headers, 3.6" Modular Pulley System, Autolite 104, NGK Spark Plug Wires, CAI, ZZP 180 T-Stat, Overkill PCM (Custom Street Tuning By Will), Goodyear Eagle F1 Tires, Hawk HPS Brake Pads, Magnaflow Magnapacks 4", SE Front Fascia
    Check Out My Car! ---
  5. #25 Re: overkill, zzp
    top 5 dead or alive OmegaRed's Avatar
    Feb 2010
    Medford, Oregon, United States
    still hearing nothing but good things about will/overkill , and he is he only one that can have us 06+ guys with a correctly functioning gas gauge... so this is the route im going
  6. #26 Re: overkill, zzp
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    So for part time worker who wants to get a new pcm that will be reliable and now mess my car up, which PCM should i go with? I want the safest one possible lol
  7. #27 Re: overkill, zzp
    Florida
    Will at overkill hands down. i do my own tuning so i have not run one of his PCM's but i have tuned a bunch of GP's here in florida and recently saw his work on a 98 GTP. Im a perfectionist, and i had no complaints about how he set up this file.
    The only tweaks needed were the usual MAF tune and bump to PE_RPM_vs_Time to get fueling dialed in. this is to be expected as unless he has access to live data from the car the fuel and spark changes are blind. This is the reason it is said that a custom tune will always be better then any box pcm. there are just too many variables that can throw fueling either way. a sub par injector, a gasket off center a bit, bad castings on the heads (seen this 1st hand how mis-aligned the castings can be while porting my heads)
    I have seen ZZP tunes on a lightly modded car cause a lot of KR. i also feel their trany settings were dangerous on the few tunes i have seen.
    For a Box tune "Get Overkilled!" and call it a day.
    i feel unless you find someone who is really good a tuning. the best setup you can get is to buy a PCM from overkill and then later have the trims dialed in by a local guy. or, if will gives the option get some scans sent to him so he can make a more tailored tune. maybe with his retune options!
    I digress.... to answer the original question "GET OVERKILLED!"
  8. #28 Re: overkill, zzp
    Kansas
    Quote Originally Posted by JDrach View Post
    Overkill.
    Waken up your car a little and potential gain a few MPGs. If you have any questions contact Will. He is a great guy and very knowledgeable. And don't complain if you email him and he hasn't reply to your email in 24 hours. The man is busy with other things in life, and it's worth your patience. Not saying it will take him that long, but still better tune and support than ZZP.
  9. #29 Re: overkill, zzp
    Dec 2011
    Champaign, IL
    Quote Originally Posted by NegativeOne13 View Post
    Overkill.
    Have a 2008 Grand Prix GXP and trying to do about my 8th key re-learn. Car remains dead, won't do a dang thing. Anyone else have trouble getting this accomplished? Car fires right up with old ECM. About to say screw and just get a refund, I don't have the time to keep messing with this.
    Doors shut, key in on position for three 10 minute cycles with a 5 second pause in between. Don't remove key on last cycle and try to start.........nothing. Then I get the starting disable due to theft system message in DIC. Wash, rinse, repeat since this morning. I'm at a complete loss and have nothing to show for $300.............
  10. #30 Re: overkill, zzp
    Jul 2012
    Chicago
    Isn't it supposed to be 30 seconds in between? Not 5? That's how it was on my Bonneville.
    Just throwin' out ideas.
    -Carl
  11. #31 Re: overkill, zzp
    May 2008
    Schuyler, NE
    Stick with stock until you can afford a tuner.
  12. #32 Re: overkill, zzp
    GT Level Member jdmgtp's Avatar
    MI
    I have to agree about the zzp tune, not impressed at all. I think all they did was bump the idle rpm up and add a little startup fueling.
    This is why I do my own
  13. #33 Re: overkill, zzp
    Texas
    Had 2 ZZP PCM's-made a previous 1.9 rockered/SSIC/plog/dp/3.4 GTP put down-271whp/325tq. Far from just an idle bump and increase startup fueling. Lol.
    Currently running a ZZP shelf tune on my 97 TGP- IC CT kit, 11 PSI, 61mm, 1.9 rockers, cutout, 2.5" exhaust, put down 346whp-again far from an idle bump and increased startup fueling. Lol
    I've also run Intense Racing and DHP shelf tunes on my car. Both were great as well.
    85 Corvette
    01 TA
    03 Z06
  14. #34 Re: overkill, zzp
    May 2008
    Schuyler, NE
    These threads are always funny.
    Looking at the files of the big companies, (zzp, intense, wbs, dhp) they are all almost identical.
  15. #35 Re: overkill, zzp
    GTP Level Member joe0813's Avatar
    Boston, MA
    i have a zzp pcm for my 3.4 set up and i dont have any problems with it... and ill also be getting there canned tune when i install my xp cam since i dont know how to tune im not going to spend 400 bucks on a tuner i have no idea how to use. i dont get why people say zzp pcms blow motors? how do you know it blew the motor and it wasnt something else
  16. #36 Re: overkill, zzp
    MI
    Quote Originally Posted by txslow6 View Post
    Glad you think it's funny but I actually LOOKED at the tune.
  17. #37 Re: overkill, zzp
    May 2008
    Schuyler, NE
    Quote Originally Posted by jdmgtp View Post
    And, what did you see?
  18. #38 Re: overkill, zzp
    Texas
    Yes it is. Want to know what's funnier than that...
    Reread your previous post. Here I quoted it for you.
    If you actually looked at the tune and knew then you would have never used the phrase "I think". Instead you would have stated what you found in the first post. This obviously implies that you are unsure and just guessing as to what was in the ****ty tune.
    85 Corvette
    01 TA
    03 Z06
  19. #39 Re: overkill, zzp
    MI
    I said "think" because it was a recollection from a year ago. I can look and confirm, so you quote me.....detective
  20. #40 Re: overkill, zzp
    Texas
    Man you guys are so easy to get riled up. I love this website.
    85 Corvette
    01 TA
    03 Z06
  1. overkill pcm
    By Biggie1720 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-22-2010, 09:11 AM
  2. overkill pcm
    By boostedcompg in forum Shops and Community Heroes
    Last Post: 01-28-2010, 01:25 PM
  3. Overkill GXP
    By GreenPrix in forum Track Sessions and Kills
    Last Post: 12-07-2008, 11:30 PM
  4. Will at Overkill
    By 04gpking85 in forum PCM Tuning
    Last Post: 11-05-2008, 09:48 PM
  5. Overkill PCM
    By gqjonb77 in forum General Tech Discussion
    Last Post: 10-17-2008, 10:44 AM
