its my day off so all ive had to do today is search...
unfortunetly the only way ive found to do this is to keep the car in open loop... otherwise, while in closed loop, the NB 02 will try to keep it a constant 14.7 no matter what you have your command set to.
the only thing we can control command afr on the V6s in closed loop (again, this is what ive found in research so if im wrong someone please correct me) is through PE mode...
otherwise were screwed... but i have seen alot of threads that are telling e85 guys to change their command from 14.7 to like 9.8 or something? logically that doesn make much since to me but it could verywell just be a "V8" thing...
