Thread: DHP Tuner inputs/outputs?
Results 1 to 7 of 7
  1. #1 DHP Tuner inputs/outputs?
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    Anyone have a schematic or know what the input pins into the DHP Tuner are? OR does anyone know where a off-board data cable for an 04+ can be found? Thanks.
    Also, I'm having a hard time getting my laptop to recognize the DHP Tuner Interface. ANyone have any thoughts? Thanks again.
    Lambokit to be built!!!!!
  2. #2 Re: DHP Tuner inputs/outputs?
    Florida
    i cant remember off hand the layout for the inputs but i think it is 1-3 and a ground? should be a sticker saying 1 2 3 G IIRC.
    as for the off-board cable... are you asking about an off-board used to flash a PCM outside of the car? if that is what you need i dont think they are sold anywhere. they are home made. i have one that i made. if you want i can make you one too. you will need to get a power supply though or i can buy one and include it in the cost.
    what serial connection are you using? they only recommend the keyspan. i tried a cheep usb to serial for use with my new laptop that doesnt have a built in serial. the cheep one didnt work so i had to get a keyspan. worked perfict. hope this answers your ?'s
  3. #3 Re: DHP Tuner inputs/outputs?
    Apr 2009
    Radford, Virginia
    Not sure what USB to serial I have. It's the one that came with my Tuner. Is the plug on the side of the Tuner (G321) used? I can't find anything about it in the User's Guide. And yes I would like an off-board cable to flash a PCM outside the car. I just need to know what wires go to what pins on the Tuner. There's a bundle of wires coming out of the PCM and only 15 going into the Tuner. Or only 4 + ground with a USB coming from the computer. I can make my own IF I had the wiring diagram. Or how much is a cable from you for a 04+ and one for a 97-03 also? Thanks
  4. #4 Re: DHP Tuner inputs/outputs?
    Apr 2009
    Radford, Virginia
    Bump... Anyone know?
  5. #5 Re: DHP Tuner inputs/outputs?
    Donating Users blowfishRus6's Avatar
    g.a.
    the 123G on the side if for a wide band if i can remember correctly.
    i had to buy a certin usb serial port, and download the software so it would communicate from my computer to the pcm. i had alot of issuies getting started myself.
    this might help, The Best Tuning Site in the World - Unreal Portal they could probably help you with an offborad also.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  6. #6 Re: DHP Tuner inputs/outputs?
    Apr 2009
    Radford, Virginia
    Thanks!!!!
  7. #7 Re: DHP Tuner inputs/outputs?
    Jan 1970
    Maquoketa, Iowa
    DOHCZ34 makes offboards, they work well.
    The pins on the side are for inputs, such as a wideband.
    To get access to some of the download sections of the powrtuner.com site you have to request it from one of the moderators. The site is a good source of information, but you may have to do some searching on your own as there are not a lot of people checking in everyday.
  1. Does the Stock deck have RCA outputs
    By jacobmh27 in forum Audio, Security & Visual Electronics
    Last Post: 09-22-2010, 12:51 AM
  2. How to hook up the A/D inputs on the DHP Powertuner?
    By Iron Indian in forum PCM Tuning
    Last Post: 06-25-2008, 09:01 AM
