Thread: hp tuners... regular or pro?
Results 1 to 15 of 15
  1. #1 hp tuners... regular or pro?
    GT Level Member jakewet28's Avatar
    Cincinnati
    So what is the difference between the hp tuners regular version and the pro version? thinking about maybe getting one soon hopefully. TIA
    VS Cam, SS Intercooler, Powerflow catback, SSAC headers, open cone, 180* tstat, 42.5lb injectors, 2.8 pulley, 3.29 gears, zzp pcm, all supporting mods
  2. #2 Re: hp tuners... regular or pro?
    Pro allows you to log 2-3 things that aren't monitored by the engine w/o sacrificing and running through unhooked wires for other items.
    Pro allows you to log w/o a computer in the car. You load your desired parameters on the cable's box and that's all you need in teh car. Keeping the abilty to log and review later w/o leaving a laptop in the car all the time.
  3. #3 Re: hp tuners... regular or pro?
    Cincinnati
    So there's no real big difference in both versions except logging without a computer?
  4. #4 Re: hp tuners... regular or pro?
    Charles City, IA
    If you live in an emissions state I would suggest pro, so you can log a wideband, if not standard will be fine and you can just wire the wideband threw the egr.
    SMGPFC Two Nipple General
  5. #5 Re: hp tuners... regular or pro?
    Lawrenceville Ga
    Pro, all the way. Black box logging is THE BOMB!!
  6. #6 Re: hp tuners... regular or pro?
    Cincinnati
    But is it really worth the extra 150 that I could be putting toward a widebar?
  7. #7 Re: hp tuners... regular or pro?
    Jan 1970
    Maquoketa, Iowa
    Do you want to delete the EGR to log wideband? Or do you want to keep the egr/ac and just get the pro version to log your wideband and possibly other inputs?
  8. #8 Re: hp tuners... regular or pro?
    Cincinnati
    Is there any difference between deleting the egr and just keeping it and getting the pro?
  9. #9 Re: hp tuners... regular or pro?
    Lawrenceville Ga
    Quote Originally Posted by jakewet28 View Post
    Yes, you still have a functioning EGR system. I would absolutely get the pro version, even if it meant having to save up for an extra couple weeks. Having the ability to log 4 extra sensors (A/D inputs) and having 2 outputs (to control relays and such) is really nice, but the main reason I'd get the pro version is for the black box logging. I had a PowrTuner first, so I know all about having a laptop in the car to log. You can log over 2 hours on the interface using the Pro version, that's worth the $150 alone to me.
  10. #10 Re: hp tuners... regular or pro?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    I have the standard version, But I log with my Ls1m. Luggin the laptop around to scan BLOWS.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  11. #11 Re: hp tuners... regular or pro?
    Donating Users chrisb's Avatar
    Bucyrus, OH
    pro is nice, well worth the extra money for me atleast. if your going to tune someone elses car how are you going to use a wideband with the standard version?
    99 Grand Prix old build- CAI, Custom exhaust, HV3, Stage 2 TB, custom tune, ported heads intense s1x cam, headers.
    Nothing great Just a small T66 Turbo with a Hv3 On a stock tranny untill i finish the other one.
  12. #12 Re: hp tuners... regular or pro?
    SE Level Member GrandZero's Avatar
    ohio
    will a bullydog tuner work on a 04 comp g? if i put on headers and an intercooler do i need to tune it right away?
  13. #13 Re: hp tuners... regular or pro?
    Hagerstown,Md
    Quote Originally Posted by chrisb View Post
    With the EGR, or any wire with a .5v referance for that matter
  14. #14 Re: hp tuners... regular or pro?
    Hagerstown,Md
    Quote Originally Posted by GrandZero View Post
    No, And yes you need a tune with a intercooler and headers and pulley drop
  15. #15 Re: hp tuners... regular or pro?
    ohio
    Thanks do you know of any tuners in the ohio area?
  1. How bad is regular gas for your gtp?
    By GMCARS4LIFE in forum General Tech Discussion
    Last Post: 08-16-2010, 02:44 PM
  2. oil: synthetic or regular??
    By WHITEGPGT06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2010, 06:46 AM
  3. Sythetic VS Regular 5W30
    By Fubisin in forum General Tech Discussion
    Last Post: 10-21-2009, 10:00 PM
  4. Replies: 3
    Last Post: 10-21-2009, 10:18 AM
