Thread: kr wierd issue
Results 1 to 7 of 7
  1. #1 kr wierd issue
    Aug 2008
    SOUTH TEXAS
    I get partial kr only.
    It goes to 1.93 and stays there.
    I had the motor rebuild and replaced the back kr sensor cause it look bad.
    What could be the problem?
    Bad Kr sensor or unpluged?
    Also is the fron kr sensor the same as the back kr sensor?
    TOGs//Stge III ZZP Blower//LS1 tb// 85 maf//XP cam //105lb spings//3" Dp& high flowcat//3.2",3.0"
    Ud plly//Msd wires//Aut 103's//CAI//ZZ PCM//ZZ P shift kit//42.5lb. 13.3@104MPH DEC 08
  2. #2 Re: kr wierd issue
    the knock sensors are the same. is the knock constant, or only in the upper rpm/boost range?
  3. #3 Re: kr wierd issue
    Aug 2008
    SOUTH TEXAS
    Only when i give it gas.
    Partial and full throttle kr stays at 1.93.
    I let go of the gas and the kr goes away.
  4. #4 Re: kr wierd issue
    ...it sounds like it would be false, but it wouldnt be constant if it was. i am confused..what does the scan look like?
  5. #5 Re: kr wierd issue
    Aug 2008
    SOUTH TEXAS
    No ses light coming on,if thats what u mean.
    Could this be the problem ( pics)
    I took of the sensor and installed a new one this afternoon.
  6. #6 Re: kr wierd issue
  7. #7 Re: kr wierd issue
    Aug 2008
    SOUTH TEXAS
    maybe? is it knocking now?
    Wont be able to scan till this afternoon.
  1. Tach acting wierd
    By ntr2def in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-08-2009, 11:04 AM
  2. GTP pcm issue with ZZP
    By Regalgs98 in forum PCM Tuning
    Last Post: 02-18-2009, 02:16 AM
  3. wierd start up issue??
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 02-10-2009, 04:25 AM
  4. Stock HU acting wierd
    By Red_GTP in forum Audio, Security & Visual Electronics
    Last Post: 07-08-2008, 09:36 PM
  5. Help with this issue please
    By TDCRacing in forum General Tech Discussion
    Last Post: 07-05-2008, 05:00 PM
