Thread: Tach acting wierd
Results 1 to 8 of 8
  1. #1 Tach acting wierd
    Dec 2008
    idaho
    I just bought a 2001 grand prix GT and drives clean and smooth no problems. recently i would say after a half hour of driving it around the RPM just dies, the car runs no problems or sputters, its as if the RPMs arent registering. its not a huge deal because my car is ok i dont have any problems, but i do want my tach to work. any ideas?
  2. #2 Re: Tach acting wierd
    Jul 2008
    sumter,south carolina
    99% sure its your Crank position sensor,get it fixed before u get stuck on the side of the road.
    02 GTP with mods 05 GP for DD
  3. #3 Re: Tach acting wierd
    Oklahoma
    ^^Pretty sure he nailed it.
    The CPS is a two part sensor, rather it may be safer to say that it generates two signals from the interupters on the back of the crank pulley. One generates a signal that gives you the RPM read out on your dash but also gives the computer information to run the traction control system. The other signal goes to your Ignition Control Module and controls spark and if that signal fails, it will leave you stranded.
  4. #4 Re: Tach acting wierd
    Jul 2008
    http://www.grandprixforums.net/cps.php heres the write up for do it yourself
  5. #5 Re: Tach acting wierd
    Oklahoma
    Well arent you the kind one.
  6. #6 Re: Tach acting wierd
    Jul 2008
    I try to be,hes new so i looked out for him.
  7. #7 Re: Tach acting wierd
    Dec 2008
    idaho
    Hey thanks a lot for the info I really appreciate it. I'll get it done
  8. #8 Re: Tach acting wierd
    Dec 2008
    idaho
    so I never got back with a reply. my car has been parked, but now that I'm back I swapped the cranhshaft postion sensor and there is no change. my tach still sits at zero once the car is warmed up. it works from cold start but then it dies as soon as the car warms up
  1. 98 GTP acting up help!!!!!!!!!
    By Red_GTP in forum General Tech Discussion
    Last Post: 08-04-2008, 05:35 AM
  2. A/C controls acting funky
    By Nowak1981 in forum General Tech Discussion
    Last Post: 07-15-2008, 04:56 PM
  3. Stock HU acting wierd
    By Red_GTP in forum Audio, Security & Visual Electronics
    Last Post: 07-08-2008, 09:36 PM
  4. please help tranny acting weird
    By ryan88z in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-05-2008, 09:17 PM
  5. Forums Acting Weird
    By 19SE92 in forum Forum Bugs/Suggestions
    Last Post: 02-29-2008, 08:03 AM
