Thread: Highway trims different from around town
Results 1 to 8 of 8
  1. #1 Highway trims different from around town
    Quincy, Mass
    When I’m driving around town my trims are good, on the rich side even. When I get on the highway the lean out to +7-9 at points. Is there a table that adds when I’m cruising in a higher gear?
    Wideband isn’t hooked up, hoping to get to that today.
    No more GP 04 Impala SS Indy:
  2. #2 Re: Highway trims different from around town
    Nothing adds to the trims or makes them go higher or lower, it's just going off your airflow tables are different loads/rpm and your o2 sensor are seeing it.
    You could try to pinpoint exactly what MAF hz you are at while cruising speeds and go in your MAF curve and add like 1-2% in that small section to see if the trims drop.
    I honestly wouldn't even care if there were like that, it's not going to change how it drives or hurt mileage if it randomly bumps up to around +7-9.
  3. #3 Re: Highway trims different from around town
    Kemmerer, Wyoming
    could also be seeing deceleration enleanment, might not go all the way to 16.4, but still could lean out.
  4. #4 Re: Highway trims different from around town
    Quincy, Mass
    Even getting on it to change lanes stays lean.
    Got the wideband hook up today but didn’t have time for a test run, idle is good, bounces between 14.6 and 15
  5. #5 Re: Highway trims different from around town
    Kemmerer, Wyoming
    how is the activity on your o2 sensor? maybe it needs changed
  6. #6 Re: Highway trims different from around town
    Quincy, Mass
    My narrow or wide o2?
  7. #7 Re: Highway trims different from around town
    Kemmerer, Wyoming
    narrowband
  8. #8 Re: Highway trims different from around town
    Quincy, Mass
    Narrowband is only 2 years old and has about 10k on it. It seems fine on the scan
  1. Getting trims in check
    By PWNED in forum PCM Tuning
    Last Post: 03-18-2015, 09:35 PM
  2. getting fuel trims dialed in
    By Timing in forum PCM Tuning
    Last Post: 04-21-2013, 10:13 PM
  3. Where could I find GT SE body trims
    By ZachBW55 in forum Visual/Body Modifications
    Last Post: 06-11-2011, 10:50 AM
  4. Fuel trims
    By zildjian102 in forum General Tech Discussion
    Last Post: 02-11-2011, 01:55 AM
  5. Help with fuel trims
    By 00gpgtp in forum PCM Tuning
    Last Post: 01-10-2009, 11:48 PM
