Thread: Noob needs help with L32 swap into GT
Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
  1. #21 Re: Noob needs help with L32 swap into GT
    May 2008
    Schuyler, NE
    Quote Originally Posted by blueguy View Post
    It's Cam.
    What Cam says goes, Nick.
    Or he gets mad.
    He's right.
    Don't go against it.
    Lol
  2. #22 Re: Noob needs help with L32 swap into GT
    GT Level Member sugaryuk's Avatar
    vancouver,bc
    I've got the instructions that came with my HPTuners sitting right in front of me-- it reads:
    CAUTION To avoid damage to your interface, only power the laptop with a fully charged laptop battery. Do not plug the laptop into another power source. The HP product obtains power from both the laptop and the vehicle. This causes unique issues when there is a voltage offset between the two voltage sources that can cause catastrophic failure. Do NOT utilize a DC to DC converter to power the laptop as doing so may cause damage to the interface of the vehicle that is not covered under any warranty. Damage to the interface or the vehicle that is caused by a voltage offset is not covered under any warranty.
    Didn't seem worth it to me to chance it so I got a new battery for the laptop. If I download both the 02 GT's pcm and my OverKill pcm, then use the comparison log to overwrite the Gt's engine tune with the OverKill L32 engine tune, and keep the GT's tranny tune and change the system(fan) and speedo values to the OverKill as well.--- should that be good to go? Or are there other parameters that need to be redone?
    02 GT- L32/Gen V, 3.3 mps, zz 1.9's, N*, slp front to back, OverKilled, 180 tstat, 104's, K&N cai, lowered with GMMP susp, 12" PBR brakes
    75 Pro-Street Vega-- Blown 383 stroker with Nos fogger system
  3. #23 Re: Noob needs help with L32 swap into GT
    Omaha, NE
    Wait... you read the instructions?
    Sent from my iPhone using Tapatalk Pro
  4. #24 Re: Noob needs help with L32 swap into GT
    Nov 2011
    NY
    Hahahahahahaha, my brain said the same!
  5. #25 Re: Noob needs help with L32 swap into GT
    vancouver,bc
    Now that I`ve made the new file/tune of my OverKill engine tune and GT tranny, when I go to flash it, do I use 'Write Calibration' or 'Write Entire'? And should I be flashing the GT's pcm or do I need to use a GTP pcm to get the 2 bar map recognized?
  6. #26 Re: Noob needs help with L32 swap into GT
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    The tune is what recognizes the MAP, not just the PCM.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  7. #27 Re: Noob needs help with L32 swap into GT
    Quote Originally Posted by sugaryuk View Post
    i would use the gtp bin file because of the map sensor. [ut the na trans file in the gtp bin. id do a full write too. the pcm dont matter really, unless its not a unlocked vin. if you got the year unlocked it should be no issue.
  8. #28 Re: Noob needs help with L32 swap into GT
    SE Level Member bcmonzai's Avatar
    Surrey, BC
    You should use the GTP pcm because Overkill may have setup tables that HPT won't let you at to copy over to the GT pcm (i.e. you need to use TinyTuner). Plus if you use the GTP pcm, you should only need to do a "Write Calibration".
    I have never used the "Write Entire" option but I know someone else who did and the pcm end up bricked because the car's battery wasn't fully charged.
  9. #29 Re: Noob needs help with L32 swap into GT
    vancouver,bc
    I seem to recall being told that the OK pcm was unlocked-- so does that mean I don't have to worry about the VIN being changed to the GT's? It seems that way because it's currently in the GT and it's running--and as we don't have any vehicle testing up here anymore do I even need it? I guess that means I'll have to blow 2 more credits to tune the 03GTP pcm, currently just have the gt license (not the entire year). Does it make sense to try just a Write Calibration and see if that works, before attempting a full write (read a few horror stories of people screwing up pcms after doing full writes).
  10. #30 Re: Noob needs help with L32 swap into GT
    Surrey, BC
    Ya, HPT credits...what else you gonna do with them? Have you read the OK tuned pcm and saved it?
    I don't know if you need to update the VIN in the OK pcm. If it sets off a security code/lite or the radio and things don't work, then I guess so. I would try running it with the OK tuned pcm as is. The GT trans is 3.29 geared like your old setup. Not sure if the valve body difference deal matters in this swap. What about test-running it on jackstands?
  11. #31 Re: Noob needs help with L32 swap into GT
    vancouver,bc
    Quote Originally Posted by bcmonzai View Post
    Made sure I saved both the OK tune and the GT's stock tune. I've actually been driving around a bit with the OK pcm and it seems to working fairly decent, tranny shifts are more firm than before but shift at right rpm. I haven't put my foot into it yet, not gonna push my luck until I figure things out. Luckily I have 3 pcms so I can afford brick a couple lol. No security light so far and only weird thing I noticed so far was that the emergency brake light came on for a bit, other than that everything seems to be functioning properly with the OK pcm.
  12. #32 Re: Noob needs help with L32 swap into GT
    May 2008
    Schuyler, NE
    Same thing. It doesn't say anything about plugging it into your house. Just a car that can have power surges.
  13. #33 Re: Noob needs help with L32 swap into GT
    Another power source is a wall outlet, but hey it's up the end user if they want to do it that way. I'll continue to just use the laptop battery itself.
  14. #34 Re: Noob needs help with L32 swap into GT
    May 2008
    Schuyler, NE
    But it's a stable power source. Huge difference from the alternator on a car.
  15. #35 Re: Noob needs help with L32 swap into GT
    vancouver,bc
    Decided to use the 03 pcm with the OK tune on it and copy the gt tranny tune to it. Seems to have worked, tranny is shifting fine-- a little bit blah on the shifts so I might start looking for better tune to firm up the gt tranny. Motor definitely needs some fine tuning, no.1 has a misfire going on, still throwing a p0134 and dam slp's are leaking at the collector/crossover. But at least it starts and drives!
  16. #36 Re: Noob needs help with L32 swap into GT
    check fuse 21 marked ign.
    rtv and band clamps for the cross over.
    swap the coils around. same with the plug wire and plug to hunt the misfire down.
  17. #37 Re: Noob needs help with L32 swap into GT
    vancouver,bc
    Already have band clamps on so time for the red stuff, might have to reposition the rear header- seems to hitting the new Dorman swaybar I put in (or flip the bar). Tried swapping the plug, wire and coil already, might be the injector? Also thought it could be the ICM, the rad got pushed into it from the accident I had in the 99GTP-may up screwed something up. Fuse checked out ok, I'll go over the wiring this weekend to see if I missed something.
  1. Not Exactly a Noob, But This Is a Noob Question
    By Hurricane87 in forum Introductions/Noob Questions
    Last Post: 07-22-2016, 02:07 AM
  2. Noob Question - Hood Swap
    By mx5xm in forum Introductions/Noob Questions
    Last Post: 10-18-2014, 10:07 PM
  3. noob to cars but looking to not be a noob :)
    By duditz in forum Introductions/Noob Questions
    Last Post: 09-06-2014, 10:05 PM
  4. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  5. Engine Swap. GTP into GT , Help im a noob. help Please:)
    By guimond47 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-17-2011, 11:10 PM
