Thread: Noob needs help with L32 swap into GT
Results 1 to 20 of 37
  1. #1 Re: Noob needs help with L32 swap into GT
    SE Level Member bcmonzai's Avatar
    Surrey, BC
    Quote Originally Posted by sugaryuk View Post
    I seem to recall being told that the OK pcm was unlocked-- so does that mean I don't have to worry about the VIN being changed to the GT's? It seems that way because it's currently in the GT and it's running--and as we don't have any vehicle testing up here anymore do I even need it? I guess that means I'll have to blow 2 more credits to tune the 03GTP pcm, currently just have the gt license (not the entire year). Does it make sense to try just a Write Calibration and see if that works, before attempting a full write (read a few horror stories of people screwing up pcms after doing full writes).
    Ya, HPT credits...what else you gonna do with them? Have you read the OK tuned pcm and saved it?
    I don't know if you need to update the VIN in the OK pcm. If it sets off a security code/lite or the radio and things don't work, then I guess so. I would try running it with the OK tuned pcm as is. The GT trans is 3.29 geared like your old setup. Not sure if the valve body difference deal matters in this swap. What about test-running it on jackstands?
  2. #2 Re: Noob needs help with L32 swap into GT
    GT Level Member sugaryuk's Avatar
    vancouver,bc
    Quote Originally Posted by bcmonzai View Post
    Made sure I saved both the OK tune and the GT's stock tune. I've actually been driving around a bit with the OK pcm and it seems to working fairly decent, tranny shifts are more firm than before but shift at right rpm. I haven't put my foot into it yet, not gonna push my luck until I figure things out. Luckily I have 3 pcms so I can afford brick a couple lol. No security light so far and only weird thing I noticed so far was that the emergency brake light came on for a bit, other than that everything seems to be functioning properly with the OK pcm.
    02 GT- L32/Gen V, 3.3 mps, zz 1.9's, N*, slp front to back, OverKilled, 180 tstat, 104's, K&N cai, lowered with GMMP susp, 12" PBR brakes
    75 Pro-Street Vega-- Blown 383 stroker with Nos fogger system
  1. Not Exactly a Noob, But This Is a Noob Question
    By Hurricane87 in forum Introductions/Noob Questions
    Last Post: 07-22-2016, 02:07 AM
  2. Noob Question - Hood Swap
    By mx5xm in forum Introductions/Noob Questions
    Last Post: 10-18-2014, 10:07 PM
  3. noob to cars but looking to not be a noob :)
    By duditz in forum Introductions/Noob Questions
    Last Post: 09-06-2014, 10:05 PM
  4. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  5. Engine Swap. GTP into GT , Help im a noob. help Please:)
    By guimond47 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-17-2011, 11:10 PM
