Quote Originally Posted by bcmonzai View Post
Ya, HPT credits...what else you gonna do with them? Have you read the OK tuned pcm and saved it?
I don't know if you need to update the VIN in the OK pcm. If it sets off a security code/lite or the radio and things don't work, then I guess so. I would try running it with the OK tuned pcm as is. The GT trans is 3.29 geared like your old setup. Not sure if the valve body difference deal matters in this swap. What about test-running it on jackstands?
Made sure I saved both the OK tune and the GT's stock tune. I've actually been driving around a bit with the OK pcm and it seems to working fairly decent, tranny shifts are more firm than before but shift at right rpm. I haven't put my foot into it yet, not gonna push my luck until I figure things out. Luckily I have 3 pcms so I can afford brick a couple lol. No security light so far and only weird thing I noticed so far was that the emergency brake light came on for a bit, other than that everything seems to be functioning properly with the OK pcm.
