I will eventually need to get my PCM tuned for my build, but I'm unsure of what it can do or handle.
So if anyone here has any experience tuning these things any info would be greatly appreciated.
Can you delete the MAF and run solely off speed density?
Can you adjust the Speed sensor input from the trans?
GTP vs F-body for instance. so I can use the factory speed sensor wire with my sensor and tone ring in the trans. Mine likely spins much faster than the GTP trans sensor. Probably closer to the F-Body trans.
