Thread: Programmed my first PCM :)
Results 1 to 6 of 6
  1. #1 Programmed my first PCM :)
    Oct 2011
    Toledo, OH
    So I bricked 2 PCMs trying to program my 05 GTP in-car with DHP. Finally built an off board harness and that worked perfect.
    Scaled my injectors +28% (33lbs, to 42.5lbs) and increased my injector skew to 130% for E85. No more +16.4 LTFT
    7"
  2. #2 Re: Programmed my first PCM :)
    where you pulling the radio fuse while using dhp to read and write the pcm?
    you got me beat, ive only bricked one so far lol
  3. #3 Re: Programmed my first PCM :)
    Oct 2011
    Toledo, OH
    The first one, no. Died while writing when I opened the door and the radio chimed. The 2nd one was writing at an incredibly slow rate and finally timed out after at least 2 hours of writing. Offboard harness wrote full .bin in under 5 minutes.
    7"
  4. #4 Re: Programmed my first PCM :)
    GXP Level Member
    Mar 2015
    Tomball
    have you been able to do a partial write? Mine are all 322 seconds for a full write.
  5. #5 Re: Programmed my first PCM :)
    Oct 2011
    Toledo, OH
    Quote Originally Posted by J57ltr View Post
    This past write was 353 seconds for a full write, not sure if this PCM is slower, and yes I can do partial writes offline.
    7"
  6. #6 Re: Programmed my first PCM :)
    Quincy, Mass
    I thought i bricked my impala Pcm. Hpt wouldn't connect and would just time out when trying. I swapped it out then for the hell of it 3 days later I put it back in and it work, read and write no problem.
    No more GP 04 Impala SS Indy:
  1. Can't get new key fob programmed
    By farmkid02 in forum Audio, Security & Visual Electronics
    Last Post: 07-25-2015, 09:05 PM
  2. Theft System Not Programmed
    By Dadillac in forum General Tech Discussion
    Last Post: 07-12-2013, 10:18 PM
  3. Theft System Not Programmed............????
    By joshuayobal in forum General Tech Discussion
    Last Post: 09-20-2010, 11:30 AM
