Thread: aeroforce gauge is lying
Results 1 to 20 of 21
  1. #1 aeroforce gauge is lying
    Kemmerer, Wyoming
    I have 2 aeroforce gauges and one reads more boost than the other. I started a thread on aeroforces discussion board and have got some help from Pat. Here is a link to the thread:
    http://aeroforcetech.com/forum/viewt...p=14624#p14624
    what do you guys think?
  2. #2 Re: aeroforce gauge is lying
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    I think to be conclusive, you'd have to test more gauges. I don't have one or a tuner.
    Logically, I wouldn't think it's a variance in vehicle wiring but the actual gauge. Those things probably fly off some line and who knows. Parts get dropped, static is discharged.. could have a wrong but similar looking part in one.
    Regardless of all that, I don't think higher lift wouldn't create that much boost leakage on a .4" drop.
  3. #3 Re: aeroforce gauge is lying
    Oct 2011
    Toledo, OH
    Quote Originally Posted by SaukRapids View Post
    They don't fly off an assembly line... They are built basically one at a time by one guy in a commercial garage...
    Anyway, OBDII runs on a single wire Serial data bus. That means one nugget of data at a time, even if it's preeeety fast at it. And to make it worse, it's not just blasting out data for anyone to read, the gauges are requesting it, so no two gauges are going to read the exact same at the same time. Even having one gauge read boost on both screens can give you different numbers on each one.
    I've shown with my triple set that each gauge will read the same when solo.
    7"
  4. #4 Re: aeroforce gauge is lying
    Quincy, Mass
    You have to change the data speed on them, it's the setting. I think the user manual shows how to do it. Be
    No more GP 04 Impala SS Indy:
  5. #5 Re: aeroforce gauge is lying
    Kemmerer, Wyoming
    Pat from Aeroforce came on and said the data bus transfers data at 40KHZ, which is pretty slow. Newer GM vehicles transfer data over 10 times faster, so because one gauge is showing one speed, there is a lag big enough to through off the readings.
    I'll have to check the settings of the data transfer rate.
  6. #6 Re: aeroforce gauge is lying
    hangover park IL
    yeah each data block takes time and samples later than the previous
    excessive PID quantity actually ****s with the pcm's primary function of running the engine calc's
    ~James~ Psychotic Gearhead
  7. #7 Re: aeroforce gauge is lying
    Yoga city
    Electrical sucks in these cars plan and simple. Baud rate sucks and can be messed with but can make things worse if not correct.
  8. #8 Re: aeroforce gauge is lying
    hangover park IL
    the electical systems and each terminal to terminal and crimp/connection isnt getting any younger or less salty with age....
  9. #9 Re: aeroforce gauge is lying
    Yoga city
    agreed, my 05's number 1 reason for issues is tired wires. besides the tq going boom lol
  10. #10 Re: aeroforce gauge is lying
    lol im surprised no one has said throw away the aero and use damn torque app......
  11. #11 Re: aeroforce gauge is lying
    Kemmerer, Wyoming
    Quote Originally Posted by 98GrandPrixIraqVet View Post
    that would actually solve the problem. only having one device collecting data would help
  12. #12 Re: aeroforce gauge is lying
    classic marshal response lol shut one of the aeros off then instead of running 2 showing the same info. what is the point if the redundancy anyways?
    no need to run a tq app nerd just dont set both aeros the same.
  13. #13 Re: aeroforce gauge is lying
    Kemmerer, Wyoming
    the cable I use is an aeroforce dual gauge cable, so I would have to run more cables for one to work. more work that I don't really feel like doing.
  14. #14 Re: aeroforce gauge is lying
    wtf youre missing the point here. why are both aeros disaying the same info to begin with is my point. i dont have a fuel gauge for my fuel gauge or a speedomoeter for my speedometer.
    yes the car has a factory lego block boost gauge thats worthless so i get using an aero to display boost.
    the oddest thing i find about your whole post is about a boost reading of all things to monitor and have a variance who gives 2 sh1ts about boost its arbitrary. read which ever your little heart desires and stick with it.
    now if you were looking at knock or something and got 2 seperate random readings then id be concerned.
    as for the boost who gives a crap if they are not spot on comparing the 2.
    ps im just busting your balls because the purpose of this thread and the point of monitoring boost with 3 different gauges including the factory lego block display makes me laugh.
    hey marshal i know you like having a boost readout for your boost readout to make sure the factory boost readout is right so im going to go ahead and put 3 more aeroforces set to read boost on the passenger side pillar and maybe 2 in the glove box and 2 more infront of the shifter and maybe 2 on the steering column even.........
    just think how fvcking awesome that would be boost gauges everywhere all reading something different.......
    lololololol.
  15. #15 Re: aeroforce gauge is lying
    GXP Level Member
    Mar 2015
    Tomball
    The PCM spits out data at a pretty slow rate so it's possible that they are getting information at different times and that's why you are getting different information as mentioned above. The maximum rate I have seen is every 173 ms so you probably not going to get the same data on something is changing quickly over time.
    Jeff
  16. #16 Re: aeroforce gauge is lying
    Kemmerer, Wyoming
    even if I only have 1 gauge set to display boost, it still reads low. like 2 lbs lower than the other.
  17. #17 Re: aeroforce gauge is lying
    Yoga city
    just wire in a analog and call it a day.
  18. #18 Re: aeroforce gauge is lying
    DING DING DING ^^^^^^^ smart man.
  19. #19 Re: aeroforce gauge is lying
    GXP Level Member
    Mar 2015
    Tomball
    If you have both gauges set to timing do they display the same?
  20. #20 aeroforce gauge is lying
    Quincy, Mass
    One gauge should be set with a higher rate than the other. One is the master and one is the slave so to speak, it's one a little lower to make that the important stuff is being read at the right time and the other shows not so important stuff like trans temp. I remember this from when they first started with the dual setups.
    You swap the rate settings to check if they match up that way. Also can unplug one from the back to shut it off.
  1. SOLD
    By glanzergtx in forum For Sale - Parts
    Last Post: 03-03-2014, 01:12 AM
  2. ------Aeroforce Gauge------
    By PWNED in forum For Sale - Parts
    Last Post: 12-12-2013, 09:46 PM
  3. You'll think Im lying!
    By Mitchstrp in forum The Rant Forum
    Last Post: 12-14-2010, 05:06 PM
  4. Aeroforce gauge ?
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 04-16-2010, 06:04 PM
