Thread: E85 tuning with DHP
Results 1 to 18 of 18
  1. #1 E85 tuning with DHP
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    I read through the 2 tuning guides but i have some questions.
    1.)So my base tune will be setup to start logging just by changing the Injector Skew Percent to 1.2-1.3? Is there anything else involved with this?
    2.)If the above is true and my LTFTs are within 10%, Ill be good to go?
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  2. #2 Re: E85 tuning with DHP
    Apr 2014
    South Haven, MI
    Anyone?
  3. #3 Re: E85 tuning with DHP
    its the injector flow rate you need to increase for the larger injectors.
    injector skew should be at 100% i think.
  4. #4 Re: E85 tuning with DHP
    Apr 2014
    South Haven, MI
    Ive already done that for my injectors. I was using the "defacto guide for tuning e85" and it mentioned bumping the skew to 1.2-1.3 depending on the time of year.
  5. #5 Re: E85 tuning with DHP
    Mar 2014
    Tucson
    I have my IFR true to the size of the injectors. My skew is 1.3125 across the board. LTFT and STFT are within 5% all the time. Haven't done a MAF tune yet.
  6. #6 Re: E85 tuning with DHP
    the skew is 1-100% in dhp.
    most of the e85 tuning talk is hp based i think. what they are changing maybe somewhere else in dhp.
  7. #7 Re: E85 tuning with DHP
    Mar 2014
    Tucson
    Oops. Missed the DHP part...
  8. #8 Re: E85 tuning with DHP
    i knew that 1.2 stuff didnt jive with dhp lol
  9. #9 Re: E85 tuning with DHP
    Apr 2014
    South Haven, MI
    The max value on the Injector Skew Percent in DHP is 200. Unless youre saying that the PCM doesnt like anything over 100.
  10. #10 Re: E85 tuning with DHP
    your right, it will go as high as 200%
    not sure how that cross's over from hp to dhp tho.
  11. #11 Re: E85 tuning with DHP
    Apr 2014
    South Haven, MI
    I guess there is only one way to find out.
  12. #12 Re: E85 tuning with DHP
    this is derricks injectors off the regal board. i forget what injectors he has but this is what he started out with, trims were a bit off.
    i added a zzp pe file to his bin and it came out pretty damn close, if it was a canned tune you could not be happier with the trims really, but i did adjust them a bit since the fuel trims re learned.
  13. #13 Re: E85 tuning with DHP
    thats for 60 lb injectors, just looked through our emails.
  14. #14 Re: E85 tuning with DHP
    Apr 2014
    South Haven, MI
    Based on what i see there, he may have 60# injectors
  15. #15 Re: E85 tuning with DHP
    i ninja'ed ya, yes 60's
  16. #16 Re: E85 tuning with DHP
    Donating Users timboku's Avatar
    Montgomery, IL
    I used 131 percent on dhp and it worked fine. .trims within 2 percent on my 60s
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  17. #17 Re: E85 tuning with DHP
    Arizona
    You guys and fuel trims....Jesus unless you have a wide band you really are setting yourself up for failure. Just cause it runs "fine" doesn't mean all your data is really correct. E85 has a wide operating range but you should always look for what your actual afr/lambda is and tune off that. Not a narrowband.
  18. #18 Re: E85 tuning with DHP
    Apr 2014
    South Haven, MI
    After talking to a better tuner, i decided to take his advice and use the injector flow rate. Ill be using 60# injectors so ill get them dialed in then add 28-32% so they flow more.
  1. pcm tuning
    By Matt Palm in forum Midwest
    Last Post: 04-12-2012, 07:57 PM
  2. Tuning Help!
    By Kejross in forum Southwest
    Last Post: 03-15-2011, 11:45 PM
  3. VE tuning....not necessary?
    By PacerSS in forum PCM Tuning
    Last Post: 09-21-2010, 08:06 PM
  4. tuning on LI
    By mpiacent in forum PCM Tuning
    Last Post: 08-10-2009, 09:50 PM
