"If you would like to "kill" the remaining visible rust after cleanup, look into a quality one-step rust converter. If you must fill a 1/4" or larger rust hole with putty, at least use a fiberglass reinforced filler."
Thats what I said about that. Bondo over converted rust is not as bad as bondo over brown rust pits. If you think it will add value, go as far as you want with it but like the others said, all the stuff we're discussing is not a proper repair. If you decide to fix it right, that starts with taking the rocker molding off. It kind of looks like theres a chunk of metal missing so find a welder, a cutoff tool, and some clean scrap metal... and let the adventure begin!
