Thread: Rust repair help
Results 1 to 19 of 19
  1. #1 Re: Rust repair help
    Waukesha, WI
    LMC cab corners are a higher quality( thicker metal and better fit).
    you could have a shop weld on a patch and you do the finish work 300$+
    you could buy a grinder from harbor frieght, buy the patch and buy some 3M 8115 panel bond adhesive and cut and step your patch and (Glue) it on, glue isnt a good term for that adhesive, it hold toyotas and GMs bedsides on. 200$+
    or buy seal out and soak the inside of the cab corner and por15 the outside until your ready to deal with it.
    theres a brace under that spot that might be slighty swiss cheesed
    hope that helps lol
    edit. thats an exteded cab? it should all be one piece from LMC, if not your looking for rear rocker section also then, i dont have a LMC book near me
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  2. #2 Re: Rust repair help
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    Quote Originally Posted by redlinepontiac View Post
    hope that helps lol
    Thanks and its not the front rocker.. idk if theres a front or a back but its not rusted under the front door at all
  1. Rust!!!!
    By E IN v Y in forum Visual/Body Modifications
    Last Post: 08-14-2011, 03:41 PM
  2. RUST!
    By Taz Magister in forum Brakes/Suspension/Chassis
    Last Post: 03-17-2011, 01:09 PM
  3. surface rust
    By Lacboi in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-07-2011, 08:58 AM
  4. Anyway to get the rust out
    By grandprix17 in forum Visual/Body Modifications
    Last Post: 01-07-2010, 01:42 AM
  5. Ive got rust
    By MikeZirpola in forum Visual/Body Modifications
    Last Post: 09-24-2009, 01:08 PM
