Thread: for every one having issues with how there cars runs...
Results 1 to 15 of 15
  1. #1 for every one having issues with how there cars runs...
    Apr 2009
    stockton ca
    Basic Things that go wrong with a 3800 powered car...
    1. Vacuum Leak: Vac leaks cause many different symptoms from unstable idle, loss in boost psi, can cause a lean a/f mixture wich can be harmful to the engine. Codes relating to vac leaks are:
    Common causes of vacuum leaks are rubber T connectors cracking/breaking during other repairs, LIM gasket failure, Throttle Body Gasket Failure, and other vacuum hose failure.
    Carb spray , chemtool, Brake Clean can all be helpful in tracking down vacuum leaks spray vacuum T areas and other connections when you find the area with the leak your rpm should change
    Also S/C'd and N/A cars could all benifit from having a mechanical Vac/Boost gauge installed that way you will see a problem before it causes damage..
    Basic automotive parts stores do not carry rubber T's the complete vacuum line setup can be purchased at the dealership or you can use rubber vac line and hard T's from the auto parts store and save around $10-$15.
    2. Chipped piston yes how fow fun caused by Knock you probably need a stock pulley or more flow mods
    check your plugs one or more could or will be smashed thats not a good sign easy fix though just get a short block with low miles swap and be done with it
    3.Crank position sensor causes car to die unexpectedly and tech to drop to zero rpms at times it is a common problem and has an easy fix remove and replace
    4. Lim gaskets oil or coolant seen in between the valve cover and blower or intake
    coolant in oil
    easy fix if not afraid to get yoru hands dirty and at least have a skill level of 5 out of 10 100 bucks in parts and a few hours work and your back on the road
    5.low knocking sound bottom end noise spun bearing opps should have rebuilt the block before modding the car or triing to cam the car...
    6.wheel bearings youl need a new hub around 80 bucks and an hours work you hear a grinding noise its annoying to other drivers on the road to just fix it
    How to's can be found for most of these on here or google thank you and come again
    this thread was not serious altho some facts may or maynot be accurate the only thing for certain is i need a job
  2. #2 Re: for every one having issues with how there cars runs...
    GTP Level Member tazyboy28's Avatar
    home town
    specs:2007 GP GT, wizair intake, ZZP headers, 3inch high flow cat downpipe. SLP power flo exhaust
  3. #3 Re: for every one having issues with how there cars runs...
    Apr 2009
    stockton ca
    i guess i could have tried harder and put better info.... hmmmm
  4. #4 Re: for every one having issues with how there cars runs...
    Minnesota
    Quote Originally Posted by TorqueAutoMotiv View Post
    haha, but seriously good post it should help alot
  5. #5 Re: for every one having issues with how there cars runs...
    Right foot should be number one
  6. #6 Re: for every one having issues with how there cars runs...
    Willoughby, Ohio
    -MAF sensor is also why your car dies
    -blower motor resistor is why you dnt got heat
    -that noise is the supercharger snout
    dnt forget these! ha good start to a thread
  7. #7 Re: for every one having issues with how there cars runs...
    Apr 2009
    stockton ca
    hey feel free to add i started as a half ass joke but it could be a good thread
  8. #8 Re: for every one having issues with how there cars runs...
    Willoughby, Ohio
    it was a good half ass joke tho,
    the leaking on the passenger floor can be fixed for $4 with a deflector
  9. #9 Re: for every one having issues with how there cars runs...
    Apr 2009
    stockton ca
    true just keep adding and ill update the top i guess
  10. #10 Re: for every one having issues with how there cars runs...
    Willoughby, Ohio
    ha i will at least it will give you something to do
  11. #11 Re: for every one having issues with how there cars runs...
    Will state again.
    Right Foot
  12. #12 Re: for every one having issues with how there cars runs...
    GTX Level Member real diehl's Avatar
    Salina, KS
    Edit title please.
    signature removed for inappropriate content.
    -bio
  13. #13 Re: for every one having issues with how there cars runs...
    if you clean up the thread a little and make sure its all 100% correct ill sticky this somewhere.
  14. #14 Re: for every one having issues with how there cars runs...
    Apr 2009
    stockton ca
    Ill work on making it more informitive with correct info jus need to do the reaserch and clear up a few points
  15. #15 Re: for every one having issues with how there cars runs...
    Apr 2009
    stockton ca
    ok if im going to make this thing real i need a little help with problem related dtc codes for vac leaks maf codes the basic codes that haunt the 3800
    do to the search bringing up so much broad info i dont have time to search it all
    any help or changes to what i have would be great
  1. Car starts runs for 3 sec and dies
    By rtwilliamson in forum General Tech Discussion
    Last Post: 06-21-2010, 01:37 AM
  2. First runs at the strip
    By Space Dynamics in forum Track Sessions and Kills
    Last Post: 04-29-2010, 09:25 PM
  3. GTP Runs too lean
    By turk182 in forum Off Topic Discussion
    Last Post: 09-17-2009, 11:30 AM
  4. car runs hot?
    By chuy09 in forum General Tech Discussion
    Last Post: 05-31-2009, 08:36 AM
  5. WTF new Infiniti SUV runs 13.5's!!!
    By Smokin2000gtp in forum Off Topic Discussion
    Last Post: 11-23-2008, 07:02 PM
