Thread: Ignition timing question
Results 1 to 5 of 5
  1. #1 Ignition timing question
    May 2014
    New Mexico
    What is the stock degrees of ignition timing a gtp should be seeing at WOT? Can it safely be turned up at all?
    Thanks!
  2. #2 Re: Ignition timing question
    Feb 2013
    37.295091, -121.930053
    that depends on a whats mods your doing.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: Ignition timing question
    May 2014
    New Mexico
    Just a 3.4" with all supporting mods. Do you happen to know stock degrees in WOT?
  4. #4 Re: Ignition timing question
    depends on your year, older models are like 15, newer 17.
  5. #5 Re: Ignition timing question
    14-16 is what it may call for, though the table will only show 9-12 because of spark adder tables built in. They add spark based on commanded AFR, anywhere from 4-8 on avg. If knock is present, you'll see it down towards 11-13 commanded.
  1. ignition timing
    By abrahamhuerta95 in forum Introductions/Noob Questions
    Last Post: 04-02-2015, 06:46 PM
  2. Engine Monitoring/KR/Ignition timing on a Windows Phone
    By pfogle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2014, 11:14 AM
  3. car is cutting ignition timing
    By BlackGT97 in forum General Tech Discussion
    Last Post: 12-30-2011, 10:51 AM
  4. Ignition Timing off on my Overkill?
    By 04CompG in forum PCM Tuning
    Last Post: 11-01-2008, 09:46 PM
  5. Engine Guru's, Help Me Understand Ignition Timing
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2008, 04:28 AM
