Thread: Sulfur/rotten egg smell after mashing on the gas
Results 1 to 11 of 11
  1. #1 Sulfur/rotten egg smell after mashing on the gas
    Feb 2014
    Grand Forks, North Dakota
    When I go wot and come to a stoplight or where I have to sit for a few seconds, I get a rotten egg smell in the car, most likely coming through the vents. I also smell it outside the car when I get out, until it blows away with the wind.
    Would it be a bad cat converter? North Dakota doesn't have emissions inspections so its no big deal, just curious.
    40th Anniversary GTP. No name brand HAI. Partially clogged cat.
  2. #2 Re: Sulfur/rotten egg smell after mashing on the gas
    St. Louis
    Yep, sounds like a partially clogged cat. Time to replace it.
  3. #3 Re: Sulfur/rotten egg smell after mashing on the gas
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    Agreed
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  4. #4 Re: Sulfur/rotten egg smell after mashing on the gas
    Feb 2014
    Alright. Since North Dakota doesn't care about emissions, do you know if I were to get a catless 3" downpipe from zzp or something would I have to get a tune? Car is totally stock by the way.
  5. #5 Re: Sulfur/rotten egg smell after mashing on the gas
    Jun 2012
    Illinois
    Just the downpipe? I don't think so
  6. #6 Re: Sulfur/rotten egg smell after mashing on the gas
    Dec 2012
    Where 4T65E's were born
    What do you drive?
    Sold.
  7. #7 Re: Sulfur/rotten egg smell after mashing on the gas
    Enfield, CT
    Well if you get a p0420 code, a tune will help or do the anti-fouler trick. I would also recommend the zzp o2 sim as a third option but at that price, I would just get a tune. better benefits.
  8. #8 Re: Sulfur/rotten egg smell after mashing on the gas
    Feb 2014
    What do you drive?
    40th GTP coupe is what I drive.
  9. #9 Re: Sulfur/rotten egg smell after mashing on the gas
    Feb 2014
    Quote Originally Posted by HighOctaneRacing View Post
    Ok. Luckily I haven't had any codes yet since I bought it a year a half ago. I might buy some SD headers but that will be sometime in the distant future.
  10. #10 Re: Sulfur/rotten egg smell after mashing on the gas
    Dec 2012
    Well with what I've learned on here, 01 and up won't like cat removed without tuning the PCM
    Sold.
  11. #11 Re: Sulfur/rotten egg smell after mashing on the gas
    Feb 2014
    Alright, I'll think on how I want to go about this. Thanks!
  1. Modded fuel rails leaking and engine knocking when mashing the gas
    By jayroca in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2014, 05:02 PM
  2. rotten egg smell
    By solidsnake1972 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-11-2013, 06:36 PM
  3. rear strut TOWERS rotten.... :(
    By guimond47 in forum Brakes/Suspension/Chassis
    Last Post: 08-09-2011, 09:39 PM
  4. 99 gt 3800 rotten egg smell
    By mikedinthecity in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-03-2009, 01:17 AM
  5. Nocking engine/smell rotten eggs...
    By bowtechguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2009, 07:30 AM
