Thread: rear strut TOWERS rotten.... :(
Results 1 to 20 of 20
  1. #1 rear strut TOWERS rotten.... :(
    Apr 2011
    sudbury
    just thrrew a new engine into my baby that i just bought. car is mint in and out eveen under, but i guess i forgot to look in the trunk....XD
    check out my strut towers here :
    Pictures by guimond47 - Photobucket
  2. #2 Re: rear strut TOWERS rotten.... :(
    Grand Rapids, MI
    at first i thought this was some sort of art exhibit..
  3. #3 Re: rear strut TOWERS rotten.... :(
    GT Level Member MBruneaux's Avatar
    Canterbury, CT
    Clean dry and seal with undercoat, unless I missed something I don't see any large clumps of rot just rusty draining water.
    2001 Grand Prix GTP - Daily Driver12" front brake upgrade ('05 Monte), Raptor tune, Open cone, Front and rear strut tower braces, SS brake hoses, BMR trailing arms, ZZP 3" catted downpipe, Dorman front sway bar, GMPP rear sway bar, solid trans and engine mount, flipped dog bones and Borla exhaust.
  4. #4 Re: rear strut TOWERS rotten.... :(
    Panama City Beach, FL
    Quote Originally Posted by brandonl2000 View Post
    Clearly.
  5. #5 Re: rear strut TOWERS rotten.... :(
    Yoga city
    Yup mines looks the same I'm cleanng and sealing myself the weldng in support
  6. #6 Re: rear strut TOWERS rotten.... :(
    Willoughby, Ohio
    YEEEEEEEP mine is even worse. this is a problem that is becomming worse over the years, mine actually started falling thru and is now beyond repair unless i weld a new quarter of a donor GP in. i had my mechanic weld a steal plate to the inside top of the shock tower as a temporary fix. i now have to part out the car next year i will be gettin anoter GP to build over winter but this SUCKS, i feel your pain
  7. #7 Re: rear strut TOWERS rotten.... :(
  8. #8 Re: rear strut TOWERS rotten.... :(
    Charles City, IA
    Tap the metal with a hammer to see if its sound, if so remove the rust and undercoat. on a side note the thumb nail pics made me trip balls for a second.
    SMGPFC Two Nipple General
  9. #9 Re: rear strut TOWERS rotten.... :(
    Apr 2011
    sudbury
    just got her fixed up tonight ill post up pictures when im done both sides. i think my fix will hold up, next step is to put por15 on all of it to stop the rust permanetly. i love how someone posted up my sub box plans:P
  10. #10 Re: rear strut TOWERS rotten.... :(
    Antioch, IL
    use eastwoods encapsulator and rust coverter. better than por15
    Eastwood Rust Converter - Convert Rust in One Step
    Rust Encapsulator - Paint Over Rust - Stop Rust and Corrosion
    severe rust use converter then encap. if not insane, wire bush off loose rust and put encap over it. Converter only works when applied on RUST only.
    2009 Challenger SRT8
    Expert at being gay.
  11. #11 Re: rear strut TOWERS rotten.... :(
    Grand Rapids, MI
    Quote Originally Posted by ITHURTZ View Post
    sounds good but damn what a price tag.
    and judging from the video that stuff takes days to dry. id hate to drive it and get it all nasty while its trying to dry.
  12. #12 Re: rear strut TOWERS rotten.... :(
    Antioch, IL
    the encap is the only one that takes a bit to dry, say 1.5hrs.
    the eastwood forum is here, good ****.
    Rust Prevention & Repair
  13. #13 Re: rear strut TOWERS rotten.... :(
    Grand Rapids, MI
    the reviews on the rust converter stuff says like 48-72 hours...
    1.5 hours is nothing though.
  14. #14 Re: rear strut TOWERS rotten.... :(
    Antioch, IL
    There site says 20 oh well. Id only use the encap, plenty have people have done it that way with no worries.
  15. #15 Re: rear strut TOWERS rotten.... :(
    Grand Rapids, MI
    why only use encap? just curious, before i invest in both products. i have pinch weld rust im determined to stop. the rest of mah car is fineee.
  16. #16 Re: rear strut TOWERS rotten.... :(
    Antioch, IL
    just personal preference is all. Maybe a little laziness to
    Put converter on the severe rusted parts, top with encap your golden
  17. #17 Re: rear strut TOWERS rotten.... :(
    Apr 2011
    sudbury
    sounds like a killer idea man. is it really proven that its better then por 15 tho?
  18. #18 Re: rear strut TOWERS rotten.... :(
    Grand Rapids, MI
    Quote Originally Posted by guimond47 View Post
    i wanna know which one's cheaper!
  19. #19 Re: rear strut TOWERS rotten.... :(
    Antioch, IL
    Well according to por15, you dont just paint it on, you also have to prep it with another product so here goes. Im not going crazy on research on where its the cheapest, I am taking it directly from both main sites.
    Por15 Prep and Ready - $17.50qt
    Por15 Paint - $47.50qt @96sq ft coverage 1 coat (needs to be top coated if exposed to sunlight)
    Total WITHOUT top coat if needed $65+ship
    Eastwood Rust Converter - $29.99qt
    Eastwood Encapsulator - $34.99qt 50sq ft with 2 coats 100sqft with 1 coat ( does not need to be top coated)
    Total $64.98+ship
    Is it proven better than por15, dont know they are probably the same. But from research ALOT of guys say eastwoods goes on easier, and is better to work with.
  20. #20 Re: rear strut TOWERS rotten.... :(
    Grand Rapids, MI
    ill probably go with an aerosol thing of the eastwoods and call it that on that. i dont have much rust at all, just some complaints on the pinch welds. i doubt it would get much worse seein as it's the south, but why not go ahead and put a wrap on it.
  1. Rusting rear strut towers
    By bankai in forum Brakes/Suspension/Chassis
    Last Post: 07-21-2011, 04:36 PM
  2. Rear upper strut mount
    By Ryan D. in forum Brakes/Suspension/Chassis
    Last Post: 06-21-2011, 10:35 PM
  3. Strut tower brace front and rear
    By SleeperGS in forum Brakes/Suspension/Chassis
    Last Post: 01-17-2011, 02:16 PM
  4. Cracks in Strut Towers
    By blkgp2000 in forum Brakes/Suspension/Chassis
    Last Post: 06-03-2010, 01:51 PM
  5. Need help with with rear strut mount??
    By 99GTP99 in forum General Tech Discussion
    Last Post: 02-18-2010, 08:27 AM
