Thread: Need help with bogging issue
Results 1 to 15 of 15
  1. #1 Need help with bogging issue
    Jul 2014
    Michigan City IN
    Im new here and I'm in need of help. I have a 01 gtp and for some reason my car will start up and go through its normal high idle then when the car warms up it will run fine for about a min or two then it drops rpms and seems to bog between 300-400 rpms. if I hit the accelerator it has about a half second hesitation then when I let off it drops to about 200rpm and lights in car dim then goes back to the bog between 300-400 rpm. ive replaced the cam sensor, coolent temp sensor, tested alternator and replaced battery. im not getting an engine light. I'm about out of ideas and starting to get frustrated. Anybody have any ideas?
  2. #2 Re: Need help with bogging issue
    we kinda need to know what you drive? gp gtp. year, miles, and last known tune up.
    if your n/a it could be a bad fpr, pull its vac line and see if its got gas in it or smells of gas.
  3. #3 Re: Need help with bogging issue
    Jul 2014
    Michigan City IN
    oh sorry. its an 01 GTP. 174k miles I replaced the spark plugs and wires about 6 months ago.
  4. #4 Re: Need help with bogging issue
    it could be a dirty throttle body if thats never been cleaned before. its best to take it off and clean it, its the back side that gets dirty.
    the cel ever flash when your driving it hard? or does it run ok driving? just the idle and start up part?
  5. #5 Re: Need help with bogging issue
    Jul 2014
    Michigan City IN
    it was weird I replaced the cam sensor about 5 days ago. it ran fine. got me to work then on the way back I was driving and coming up to a stop light and when I took my foot off the accelerator it damn near died and I had to drive with to feet to keep the car running. then it went back to the same bogging issue. ive tried to look it up and ask around but I get so many different answers and nothing seems to be working lol. and sorry im kinda nooby whats the cel?
  6. #6 Re: Need help with bogging issue
    cel= check engine light.
    test the fuel pressure yet at the rail? you can do the free rental at the parts stores. fuel pump maybe taking a slow death. you want to see a good 42 psi or more.
  7. #7 Re: Need help with bogging issue
    does it feel gut less when you floor it? like its got no power going down the road? or the exhaust stink bad? if so it could also be a clogged up cat with those miles you have.
  8. #8 Re: Need help with bogging issue
    Jul 2014
    Michigan City IN
    oh yeah im not getting any cel. I checked my pressure I think I had like 37. ive heard something about a fuel resister or something that goes out but haven't found any other info on it or other symptoms
  9. #9 Re: Need help with bogging issue
    re check the pressure, if its that low it wont run well at all.
    and your year i dont think it has a high speed resistor. thats a 97 -00 deal
  10. #10 Re: Need help with bogging issue
    Jul 2014
    Michigan City IN
    sorry I didn't see your other post. I started to notice my exhaust here lately now that you mention it. how can I test my cat and if it is bad do I just get a new cat and pipes?
  11. #11 Re: Need help with bogging issue
    Jul 2014
    Michigan City IN
    okay so if I test it again and I get anything lower than 42 it would prolly be my pump then?
  12. #12 Re: Need help with bogging issue
    what you can do is remove the up stream o2 sensor from the rear exhaust manifold, this will make a damn good exhaust leak. if the the car has more power now the cats clogged. you need a o2 socket to remove it.
    you can also put the car on ramps or jack stands, wait for it to cool off and bang on the cat and listen for it to rattle inside. if so its shot.
    you can also drive it hard at night for a bit, then pull over to see if its glowing red. if so its clogged up.
    if the cats bad the cheap way would be to have a shop just cut out the old one and weld in a new one. or buy a walker down pipe with cat.
    being a 01 that year dont like the cat deleted.
  13. #13 Re: Need help with bogging issue
    Quote Originally Posted by Spawn1173 View Post
    yup, or the filter is clogged up solid, if thats not been changed do that too.
  14. #14 Re: Need help with bogging issue
    Jul 2014
    Michigan City IN
    awesome thanks so much man. i'll update tomorrow after I check it out.
  15. #15 Re: Need help with bogging issue
    you got it, good luck.
  1. bogging issue in cammed l67
    By wexcw in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2014, 08:03 PM
  2. Bogging
    By boothe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2012, 07:41 PM
  3. wierd bogging issue
    By 91gpse in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-23-2010, 10:16 PM
  4. bogging?
    By backinblackgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-28-2010, 05:03 PM
