Thread: How to bypass the BBC to get more boost
Results 1 to 20 of 27
  1. #1 How to bypass the BBC to get more boost
    Jan 2014
    New Knoxville Oh
    Is this possible
    Taz238
  2. #2 Re: How to bypass the BBC to get more boost
    Don't mess with it. You'll just end up messing something up.
  3. #3 Re: How to bypass the BBC to get more boost
    Florida
    bypassing the bbv will only cause you to enter boost sooner and when you don't need to be in boost. also you will lower your gas mileage and raise the chance of having part throttle kr that can damage the engine. like said leave it alone.
  4. #4 Re: How to bypass the BBC to get more boost
    Jan 2014
    New Knoxville Oh
    O OK how can I get more then eight pounds
    Taz238
  5. #5 Re: How to bypass the BBC to get more boost
    smaller pulley
  6. #6 Re: How to bypass the BBC to get more boost
    Jan 2014
    New Knoxville Oh
    So head job is my next step
    Taz238
  7. #7 Re: How to bypass the BBC to get more boost
    Nov 2011
    NY
    Quote Originally Posted by Taz238 View Post
    Taz238
    Maybe you should read up just a little bit and the mysteries of the world, including what the S/C 3800 can do for you! It's all here, you just got to put a little effort into it (search).
  8. #8 Re: How to bypass the BBC to get more boost
    Just slap a 3.2 on there, 12 psi easy.
  9. #9 Re: How to bypass the BBC to get more boost
    Nov 2011
    NY
    O.o
    lol
  10. #10 Re: How to bypass the BBC to get more boost
    GTP Level Member Twizted 1's Avatar
    Jul 2013
    Summertown Tn
    Don't say that FFDP, then he'll be posting up wanting to know what a Miss is and why parts of his plugs are missing! Lmao
    If you haven't read about Modding these engines just keep your hood closed until you catch up on more reading.
    Search, search, and more search. Thats the best advice I am giving.
    Sent from Not so smart smartphone
  11. #11 Re: How to bypass the BBC to get more boost
    Jan 2014
    New Knoxville Oh
    Quote Originally Posted by Twizted 1 View Post
    I ain't Retarted I have built a lot of engines and I know I can't just slap on a smaller pulley BC u need to put new valve springs rockers etc
    Taz238
  12. #12 Re: How to bypass the BBC to get more boost
    Taz238
    your way off base, you need headers, and a i/c or e85 to run that small a pulley. or boom. you dont "need" valve springs or rockers.
  13. #13 Re: How to bypass the BBC to get more boost
    GTP Level Member WhiteLightningGTP's Avatar
    Nov 2012
    Frankenmuth, MI
    I ain't Retarted
    You're correct.
    troll?
    2004 Comp G "The Panda"- low, e85, big brakes SOLD
    2002 Trans Am- 6 speed, bolt ons or something, it's slow.
    2006 Silverado- forged ls2, 4l80e, plate kit, also slow...
  14. #14 Re: How to bypass the BBC to get more boost
    Mercer, Pa
    There is no more boost. The boost controller bypass's the boost during casual driving, when you put your foot down the valve closes and gives you everything the supercharger has.
  15. #15 Re: How to bypass the BBC to get more boost
    Jan 2014
    New Knoxville Oh
    Im ordering the stage six performance kit from 3800 performance
    Taz238
  16. #16 Re: How to bypass the BBC to get more boost
    Aug 2013
    McDonald PA
    That's probably a waste. Your paying for convenience of having stuff put in one spot for you. Go make your own intake and buy a set of headers and a scan gauge then start from there
  17. #17 Re: How to bypass the BBC to get more boost
    Jan 2014
    New Knoxville Oh
    It comes with brand new valve train internals and shift kit different gear for tyranny and stronger 4th
    Taz238
  18. #18 Re: How to bypass the BBC to get more boost
    Mercer, Pa
    $2500 no intercooler and press on pulley.
    I rather have 1.9 rockers and a intercooler than new valve train.
  19. #19 Re: How to bypass the BBC to get more boost
    Jan 2014
    New Knoxville Oh
    Then what should I do for the head if I'm wanting to put the m90 supercharger smaller pull like a low three
    Taz238
  20. #20 How to bypass the BBC to get more boost
    Mercer, Pa
    Safely Modding Your 3800! http://www.grandprixforums.net/showthread.php?t=67580
    Start hear. If you look at the first 3 or 4 threads in the general tech section they talk about headers, rockers exhaust etc...
    If you want to go turbo or stick with the M90 supercharger. Turbo faster but all the money up front.
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. Boost Bypass Valve is forcing boost at idle and reverse.
    By 94GrandPrixSE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2013, 09:37 PM
  3. boost bypass
    By Erik Adam Rodriguez in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-06-2012, 02:06 PM
  4. boost bypass mod
    By mcsddd in forum General Tech Discussion
    Last Post: 08-19-2010, 07:50 PM
  5. Boost Bypass mod
    By BADAZGTP in forum General Tech Discussion
    Last Post: 05-30-2008, 11:49 AM
