Thread: how to get the crank pulley off without impact
Results 1 to 10 of 10
  1. #1 how to get the crank pulley off without impact
    Apr 2013
    Union City, In
    i have a 99 grand prix gtp and i am trying to get my crank sensor changed and cant get the pulley off. Anyone have any tips i dont have a impact gun.
  2. #2 Re: how to get the crank pulley off without impact
    take the plaxtic inspection plate off the bottom of the tranny, then clamp the flex plate with a pair of vice grips, then use a breaker bar and a pipe to break the bolt free.
    you need the right puller to remove the balancer, and the right size bolts.
    http://www.grandprixforums.net/showt...e+crank+sensor
  3. #3 Re: how to get the crank pulley off without impact
    Florida
    ^^ Use a pair of vicegrips on the flexplate, and use a big ass breaker bar. And yes, it is a normal threaded bolt.
  4. #4 Re: how to get the crank pulley off without impact
    Apr 2013
    Union City, In
    which way do i spend the breaker bar as n are they regular theads or reverse and tht is ihow we are doing it lol
  5. #5 Re: how to get the crank pulley off without impact
    say the bar is straight up you push it to the firewall, righty tighty, lefty loosey.
  6. #6 Re: how to get the crank pulley off without impact
    or the redneck way, using the starter to break the bolt free.
  7. #7 Re: how to get the crank pulley off without impact
    Redneck way ftw
  8. #8 Re: how to get the crank pulley off without impact
    Florida
    If you do the 'starter trick' make absolute sure that the bar is not going to move any, and that you only bump the starter. It works great too btw.
  9. #9 Re: how to get the crank pulley off without impact
    Jan 2009
    Tallahassee, FL
    That didn't work for me at all. Mine took a few minutes with an impact to get off.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  10. #10 Re: how to get the crank pulley off without impact
    ive seen vids where they used a jack stand to lay the bar on, then tap the starter.
    people always say to disable the engine so it cant start, i dont see the big deal, just turn the key to off after you click it.
  1. gap on crank pulley?
    By frozenlead in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-06-2011, 06:59 AM
  2. Crank Pulley out of Position
    By marcheer in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-26-2011, 02:43 PM
  3. Crank Pulley
    By Explicit_Spade in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2011, 04:04 PM
  4. crank pulley?
    By chickenfried in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-11-2010, 10:25 PM
  5. Removing Crank Pulley
    By Poil336 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-20-2010, 12:57 PM
