Thread: fuel issue?? 99 gtp
Results 1 to 20 of 30
  1. #1 fuel issue?? 99 gtp
    Apr 2013
    Union City, In
    I have a 99 grand prix gtp with 150k miles. I was driving down the road and the car would just shut down. When i tried starting it again it would start then die right away. I was told by multiple ppl it was the fuel pump so i changed it last night, driving home after changing it last night it ran fine for about 15min then as i am driving (50mph) down the road it just died. Tried starting it and it starts then dies right away. My next guess is bad relay or brain box? Any ideas any help would be awesome.
  2. #2 Re: fuel issue?? 99 gtp
    Apr 2013
    Union City, In
    btw it has a brand new fuel filter
  3. #3 Re: fuel issue?? 99 gtp
    Mar 2013
    Spring, TX
    Did you try bending the relay tab to set the pump in high speed mode? Just an idea.
  4. #4 Re: fuel issue?? 99 gtp
    Apr 2013
    Union City, In
    could these issues be caused by a bad relay? but no i havent
  5. #5 Re: fuel issue?? 99 gtp
    Mar 2013
    Spring, TX
    Try this first. It's worth a shot.
  6. #6 Re: fuel issue?? 99 gtp
    sounds like a crank sensor really, the bypass trick is if it dont start up.
    did the tach drop to zero before it stalled? if so its the crank sensor.
  7. #7 Re: fuel issue?? 99 gtp
    Mar 2013
    Spring, TX
    You would know better than I would Scotty. I just thought I'd take a shot in the dark and suggest it haha.
  8. #8 Re: fuel issue?? 99 gtp
    Apr 2013
    Union City, In
    yes it did drop to zero but wouldnt my car throw codes on the dash? i have no codes on my dash but is that the problem?? like you said it does hit zero before completely dying
  9. #9 Re: fuel issue?? 99 gtp
    you need a crank sensor for sure.
    and no, this sensor sadly hardly ever set the cel on the dash, why idk. but it should lol
    the how to. http://www.grandprixforums.net/showt...e+crank+sensor
  10. #10 Re: fuel issue?? 99 gtp
    Apr 2013
    Union City, In
    thanks alot!!!! and yeah that is dumb it should throw codes
  11. #11 Re: fuel issue?? 99 gtp
    Dec 2012
    Where 4T65E's were born
    Obviously the tach goes to 0 when it shuts off...because it's no longer running. What he meant is does it go to 0 about a second before it shuts off? You may have understood that, I'm not sure but just wanted to clarify. I'd hate for you to replace it and still have the issue or something.
    Sold.
  12. #12 Re: fuel issue?? 99 gtp
    Apr 2013
    Union City, In
    Replaced crank sen an still will start then die it. It is doing the same thing as before except now it dont hit zero then die it jus dies. So far has new fuel pump new crank sens and new fuel filtrt help please i am totally lost
  13. #13 Re: fuel issue?? 99 gtp
    Feb 2013
    37.295091, -121.930053
    did you hack the wires when you changed your fuel pump? when I just replaced mine I didnt hack the wires. It could be that the a connection is not good enough to let the pump run it could be randomly connecting and disconnecting allowing it run then turn off. but thats just my 0.02
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  14. #14 Re: fuel issue?? 99 gtp
    Apr 2013
    Union City, In
    They are all connected good i dont think the pump was bad
  15. #15 Re: fuel issue?? 99 gtp
    will it drive? then stall? or start then stall?
    if its start then stall, try the resistor bypass like posted by the captain up there.
  16. #16 Re: fuel issue?? 99 gtp
    Apr 2013
    Union City, In
    What is the res bypass? And start stall
  17. #17 Re: fuel issue?? 99 gtp
    you turn the key it starts, then less then 5 seconds it stalls.
    if you bend this tab out on the relay as posted here, its should stay running, this puts the pump in high speed mode full time. if the resistor is bad this makes it works, and tell you the resistor is bad.
  18. #18 Re: fuel issue?? 99 gtp
    Apr 2013
    Union City, In
    I see it up there lol
  19. #19 Re: fuel issue?? 99 gtp
    Feb 2013
    better question is do you have fuel shooting out of the rails?
  20. #20 Re: fuel issue?? 99 gtp
    Apr 2013
    Union City, In
    Which way do i bend tab 85 and yes i got pressure in rail thats the only reaaon it is startin
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Fuel issue
    By Blowblackorgetback in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-14-2012, 06:34 PM
  3. Fuel Related Issue??? Or not??
    By SilvrGrandPrixGT in forum General Tech Discussion
    Last Post: 12-05-2011, 06:52 PM
  4. Possible fuel pump issue.
    By SleeperGS in forum General Tech Discussion
    Last Post: 11-29-2011, 01:58 PM
  5. Another issue, fuel? please help!
    By Pittman06 in forum General Tech Discussion
    Last Post: 01-22-2010, 12:28 AM
