Thread: Rear spark plugs
Results 1 to 20 of 22
  1. #1 Rear spark plugs
    Banned
    Oct 2013
    Moorhead, MN
    ... Are AIDS.
  2. #2 Re: Rear spark plugs
    Holy valve cover leak batman.
  3. #3 Re: Rear spark plugs
    Banned
    Oct 2013
    Moorhead, MN
    You like that? The engine was 100x worse when I got it. Most of it is cleaned up now (besides the backside). Once I get the wires on, it's gonna get a brake cleaner bomb!
    When I got the car.
    Where I'm at as of today.
  4. #4 Re: Rear spark plugs
    That's much cleaner.
    The red was a bit overwhelming for the morning though. Keep the hood down on the way to work
  5. #5 Re: Rear spark plugs
    ps.. put the nut back on the engine bracket, if you haven't already.
  6. #6 Re: Rear spark plugs
    Banned
    Oct 2013
    Moorhead, MN
    I dumped a bunch of brake cleaner and Purple Power on it about a month ago.
    About halfway through I walked around the car and sh#t myself...
    The neighbor(whose house it drained towards) was not impressed.
  7. #7 Re: Rear spark plugs
    Banned
    Oct 2013
    Moorhead, MN
    There's no question about it... That spark plug is siezed in there. Even when I can get that socket on there, I turn until it just spins off the plug.
    I soaked it in PB BLASTER all night and morning.
    Murphy's Law ftl.
  8. #8 Re: Rear spark plugs
    Portland Oregon
    If the back of the engine didn't look so flammable I'd say put some heat on it
  9. #9 Re: Rear spark plugs
    GTP Level Member tms8582's Avatar
    Washington Michigan
    I'm assuming your turning it the correct way given that you go the other two out? I'd try cleaning it real good with brake clean and digging all that crud out around the plug. Make sure to get a clean good condition 6 sided socket on it. The PB blaster and oil will cause the socket to slip off easier. a breaker bar should help too.
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  10. #10 Re: Rear spark plugs
    May 2012
    Pittsburgh
    Have you tried it with the engine warmed up a bit?
  11. #11 Re: Rear spark plugs
    Banned
    Oct 2013
    Moorhead, MN
    Right. Cause I'm gonna run my engine with a broken spark plug in it.
    If I get lucky, maybe it'll fall INTO the compression chamber. Lol.
    No. And that's not an option.
  12. #12 Re: Rear spark plugs
    Apr 2012
    Goderich, Ontario
    Could always get a new/ used set of heads.
    -Paul Walker
  13. #13 Re: Rear spark plugs
    Washington Michigan
    Did you clean it up and dig that crud out and use a clean socket with a breaker bar? A pipe on the end of your ratchet will work too.
  14. #14 Re: Rear spark plugs
    Banned
    Oct 2013
    Moorhead, MN
    VICTORY!!!
    <and to no surprise, no antiseize)
  15. #15 Re: Rear spark plugs
    Banned
    Oct 2013
    Moorhead, MN
    Tms, I did everything you said. Used a whole can of brake cleaner, switched to my Kobalt 6-point sockets, and put the socket onto the plug, then attached the breaker.
    Plus I removed the alternator mounting bolt, had the engine tipped forward, and I was standing on top of my engine, while picturing the socket slipping and me faceplanting into the stb bar and knocking out my teeth.
    No hard hits on it, just slow brute force, I did 3 rotations with the breaker.
    But as soon as it "broke", it came off super easy.
  16. #16 Re: Rear spark plugs
    Washington Michigan
    Good deal! Make sure to avoid over tightening the new ones. Glad you kept all your teeth too!
  17. #17 Re: Rear spark plugs
    May 2012
    Pittsburgh
    Quote Originally Posted by Thompsju View Post
    Whoops - I was viewing the thread on my phone and didn't see the broken plug. Figured you just had a stuck one.
    Glad you got it out.
    Active Roster: 2006 Grand Prix GT - Supercharged/Intercooled 2005 Mustang GT - 2012 Impala LT
    Injured Reserve: 2000 Regal GS - 1993 Mustang LX
  18. #18 Re: Rear spark plugs
    Don't fault me for it..but I would if i needed heat. It'll run like crap, but it'll run and it'll work. I've had to run and engine while pulling an O2 sensor to keep it heated in the past. In the end, your perserverence paid off.
  19. #19 Re: Rear spark plugs
    May 2012
    Pittsburgh
    Agreed - I'd probably pull the injector clip on that cylinder too though. Not much chance of washing down the cylinder at idle, but I guess I'd still be a little afraid of wearing the rings a little faster with un-burnt gas sitting in it.
  20. #20 Re: Rear spark plugs
    GTP Level Member Twizted 1's Avatar
    Jul 2013
    Summertown Tn
    Wouldn't hurt a thing for that short amount of time running. And the plug isn't going to fall into the engine, if anything it'll get blown out.
    Glad you got it out though.
    Sent from my SGH-I747 using Tapatalk 2
  1. Rear spark plugs
    By Thompsju in forum Introductions/Noob Questions
    Last Post: 10-16-2013, 07:59 PM
  2. Spark plugs?
    By 1998GRANDPRIX in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-01-2013, 10:06 AM
  3. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
  4. I've got an 05 grand prix and I'm having trouble with the rear spark plugs.
    By learningtoworkoncars in forum General Tech Discussion
    Last Post: 09-16-2011, 10:34 AM
  5. spark plugs
    By NEONNIGHT34609 in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-07-2008, 09:43 PM
