"I still cant hear the new pump turn on" "tried to crank to see if fuel would squirt out but nothing"
So you said the fuel pump won't run, but you have power at the connector going to the tank?
yes there is power at the fuel pump connector but it wont run there is also plenty of gas in the tank, I'm trying to look for open wires or loose connections as I said the battery is brand new thats the first thing I replaced, I have no idea where the crank sensor is located or how to test it I am still searching for a manual for the vehicle the engine cover says 3800 series II
