Thread: 1998 Grand Prix GTP Supercharged, Clicks but won't Crank
Page 3 of 3 FirstFirst 123
Results 41 to 53 of 53
  1. #41 Re: 1998 Grand Prix GTP Supercharged, Clicks but won't Crank
    Oct 2013
    Omaha
    Cool appreciate info I will try after work
  2. #42 Re: 1998 Grand Prix GTP Supercharged, Clicks but won't Crank
    Oct 2013
    Omaha
    Jumped the starter same thing wouldn't turn over. Just sparks and clicks
  3. #43 Re: 1998 Grand Prix GTP Supercharged, Clicks but won't Crank
    if your getting 12 volts at the end of the pos cable to the starter, its time to change it.
    test it out of the car, go from there.
  4. #44 Re: 1998 Grand Prix GTP Supercharged, Clicks but won't Crank
    Oct 2013
    Omaha
    Starter is good that was the first thing I changed before the battery. With these chip keys would a error in the key cause this?
  5. #45 Re: 1998 Grand Prix GTP Supercharged, Clicks but won't Crank
    you got a power issue to the starter then. you need a ohm meter or some way to test your power at the starter.
    could be a ignition harness too maybe.
    the grounds are all on and tight on the tranny bell housing? 1 fat, 2 thin wires bolt there, make sure the wires are tight in the loop they used to put on the stud.
    and the little wires are on the correct studs of the starter?
  6. #46 Re: 1998 Grand Prix GTP Supercharged, Clicks but won't Crank
    Oct 2013
    Omaha
    Can you explain why it tries to turn over after I crank it manually with a Breaker-Bar then locks up?
  7. #47 Re: 1998 Grand Prix GTP Supercharged, Clicks but won't Crank
    not a clue. thats very odd.
    how hard is it to turn when you turn it with the crank bolt? is it hard to turn? or smooth feeling?
  8. #48 Re: 1998 Grand Prix GTP Supercharged, Clicks but won't Crank
    Oct 2013
    Omaha
    pretty smooth would the alternator keep it from cranking
  9. #49 Re: 1998 Grand Prix GTP Supercharged, Clicks but won't Crank
    it could if it dont spin freely, the a/c clutch can also keep it from turning if its fubared and locked up.
    take the belts off spin all the pulleys by hand.
  10. #50 Re: 1998 Grand Prix GTP Supercharged, Clicks but won't Crank
    north carolina
    big ,do like scotty said take the belt/belts off,and plugs out if it doesnt turn freely then,
    then you have either a weak starter or internal engine problems.i've seen starters work
    off the engine and be weak enough to not turn engine.
  11. #51 Re: 1998 Grand Prix GTP Supercharged, Clicks but won't Crank
    Oct 2013
    Omaha
    ok will try on friday
  12. #52 Re: 1998 Grand Prix GTP Supercharged, Clicks but won't Crank
    Banned
    Oct 2013
    Moorhead, MN
    Or just bite the bullet and get it inspected by a mechanic.
    Out $40, or this headache?
    Or replace the starter already.
  13. #53 Re: 1998 Grand Prix GTP Supercharged, Clicks but won't Crank
    Banned
    Oct 2013
    Moorhead, MN
    *crickets*
  1. My 1998 Pontiac Grand Prix Gtp Supercharged
    By Xereck in forum Members Rides
    Last Post: 02-12-2012, 08:19 PM
  2. 1998 Grand Prix GTP 2 door 3800 Supercharged
    By Litt52 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-29-2011, 07:24 AM
  3. 1998 grand prix GT wont crank
    By li0nhe4rtt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-04-2010, 04:23 AM
  4. 1998 Pontiac Grand Prix GTP Supercharged
    By Spartan GL in forum Introductions/Noob Questions
    Last Post: 12-07-2009, 11:17 PM
