Thread: new to this fourm.
Results 1 to 8 of 8
2000gtpblackbetty new to this fourm. 10-13-2013, 12:49 AM
2000gtpblackbetty Re: new to this fourm. 10-13-2013, 09:28 AM
Fivefingerdeathpunch Re: new to this fourm. 10-13-2013, 10:31 AM
2000gtpblackbetty Re: new to this fourm. 10-13-2013, 11:52 AM
Fivefingerdeathpunch Re: new to this fourm. 10-13-2013, 11:16 PM
Thompsju Re: new to this fourm. 10-13-2013, 08:44 PM
2000gtpblackbetty Re: new to this fourm. 10-14-2013, 12:27 AM
2000gtpblackbetty Re: new to this fourm. 10-14-2013, 12:28 AM
  1. #1 new to this fourm.
    Oct 2013
    columbia
    has anyone ever put a gtp motor in a gt car. and if so how hard is it.
  2. #2 Re: new to this fourm.
    Oct 2013
    columbia
    i have a bot cars one is a 2000 gtp with a trashed body and trans. then i have a 2002 gt that caught fire. i have both cars and both r gutted in the engine bay.
  3. #3 Re: new to this fourm.
    Yeah you can, the swap is easy as pie, sorta.
    Its getting it to run correctly that can be an issue. A custom PCM tune would be needed aswell.
  4. #4 Re: new to this fourm.
    Oct 2013
    columbia
    even if i use the 2000 pcm on the 2002 gt
  5. #5 Re: new to this fourm.
    Quote Originally Posted by 2000gtpblackbetty View Post
    You can swap the wire harness over to the GT, and the PCM.
    But the trans is different. Its the same case, but parts inside and way its controlled is different than the GTP's 4T65e-HD transmission. Files are different, so it wouldn't drive anywhere.
  6. #6 Re: new to this fourm.
    Banned
    Oct 2013
    Moorhead, MN
    Or you could just install a supercharger to a GT. lol
  7. #7 Re: new to this fourm.
    Oct 2013
    columbia
    I already uave transfered the final drive and valvle body with a shift kit into the gt trans.
  8. #8 Re: new to this fourm.
    Oct 2013
    columbia
    The 2002 gt caught fire so harness and motor are junk
  1. New to the fourm! And i need a little help :S
    By 96gpgtp in forum General Tech Discussion
    Last Post: 02-23-2013, 07:58 PM
  2. Im new to this fourm
    By Shorter in forum Introductions/Noob Questions
    Last Post: 08-26-2011, 02:58 AM
  3. New To The Fourm-97 GT 2 door
    By 97PrixDD in forum Introductions/Noob Questions
    Last Post: 06-19-2010, 11:42 PM
  4. new to this fourm
    By 02PrixGT in forum Introductions/Noob Questions
    Last Post: 03-21-2010, 10:43 PM
  5. Newbie To Fourm
    By Antivikings57 in forum Introductions/Noob Questions
    Last Post: 09-27-2009, 11:16 PM
