Thread: Major Problem
Results 1 to 9 of 9
  1. #1 Major Problem
    Jul 2013
    GA
    I am seeking help with an intermittent problem with a 2004 Grand Prix. I will be driving along and the engine cuts-off. This generally only happens when it is a hot day or if the car has been sitting in the sun. Generally I can restart the car immediately; the only exception has been when it was a super-hot day and it would not restart for about 15 minutes. Does anyone have any experience with this?
    Also, where is the access to the fuel pump on this car? I know it is in the trunk for some models.
  2. #2 Re: Major Problem
    That sounds pretty common for a crank sensor. Have you gotten any codes from it at all?
  3. #3 Re: Major Problem
    Jul 2013
    GA
    No codes. Just replaced the crank sensor...didn't even make it home from the shop before it happened again.
  4. #4 Re: Major Problem
    Aug 2011
    'Merica
    there is no access panel for the pump in 04+ GP's
  5. #5 Re: Major Problem
    Quote Originally Posted by Below Average Joe View Post
    Yea there is 04 can access from trunk. I believe some 05s had it as well. 06-08 I believe they switched it again.
    To OP pull the rear seat down and then lift up the carpet from the trunk should see the access panel
    04 Comp G.
  6. #6 Re: Major Problem
    This ^^^
  7. #7 Re: Major Problem
    Aug 2011
    'Merica
    I had no idea....I stand corrected lol
  8. #8 Re: Major Problem
    Lol you'll be grateful if you ever end up having to change it
    04 Comp G.
  9. #9 Re: Major Problem
    Ok.. if the crank sensor didn't do it and you have no codes. Try unplugging the maf sensor and starting the car. Might take a little throttle to get it running. Drive w/o the maf connector on for a bit and see if it stalls.
  1. Major problem please help
    By Logan541 in forum General Tech Discussion
    Last Post: 07-30-2012, 10:08 AM
  2. Major work done....now having major problem
    By L36 Killer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-14-2012, 11:14 PM
  3. Major a/c problem
    By GrandPrix08Ky in forum General Grand Prix Discussion
    Last Post: 06-22-2012, 03:04 PM
  4. New to GTP and have major problem
    By phantom2 in forum Introductions/Noob Questions
    Last Post: 09-23-2010, 11:02 PM
  5. Help Major problem
    By Krazicustom in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-08-2009, 09:16 AM
